Thread: Non of the electricals working on the left side of my 2005 mk5 gti
Results 1 to 9 of 9
  1. Exclamation Non of the electricals working on the left side of my 2005 mk5 gti
    Apr 2010
    Johannesburg, South Africa
    My vehicle went in for repais three weeks ago and came back with non of the electricals working on the left side( no electric windows, central locking or mirror ). I ve sent the car back to the dealer but they cant find anything wrong with the car. Please help
  2. Re: Non of the electricals working on the left side of my 2005 mk5 gti
    Kinross Scotland
    Quote Originally Posted by Moeg5 View Post
    As all these items run from their own control modual which are signaled over the canbus system from the central convieniance controller perhaps the canbus connector is loose or a wire has been broken (in the door flex connecter) of the canbus wiring
    Tiguan 2.0 4Motion 140PS 01/07/2013
  3. Re: Non of the electricals working on the left side of my 2005 mk5 gti
    Canada
    There is one controller in the door that does all those function. they are renowned to go faulty. Also the connection in the door pillar to the door can cause a few issues...check it not wet.
    You need someone with VCDS (Vag-com) to help you with this.
    VW Tiguan 4motion 2.0T 2015 - Awesome snow churning 4x4 GTI 😉
  4. Re: Non of the electricals working on the left side of my 2005 mk5 gti
    May 2007
    17 Post(s)
    What repairs were carried out?
    Does the fuel flap release switch work? (fuel flap release should work without the ignition being on, the other things wont)
    Do the drivers door window switches light up when you switch the lights on?
    Regards.
    Jim.
  5. Re: Non of the electricals working on the left side of my 2005 mk5 gti
    Kinross Scotland
    Quote Originally Posted by onzarob View Post
    Hi and regards to onzarob as I am not trying to contradict him as there may well be different build levels/upgrades ect, but here is a scan of a 2008/2009 mkv match which shows seperate control moduals for the doors, and Elsawin does the same.
    My Passat had one controller with just motors in the doors for the locks and windows, but the golf appears to be different.
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    56-Radio -- Status: OK 0000
    62-Door,Rear Left -- Status: OK 0000
    Address 01: Engine Labels: None
    Part No SW: 03G 906 021 TM HW: 03G 906 021 AB
    Component: R4 1,9L EDC G000AG 2763
    Coding: 0000077
    Shop #: WSC 01357
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans Labels: None
    Part No SW: 0AM 300 046 F HW: 0AM 927 769 D
    Component: GSG DSG AG7 402 0803
    Coding: 0000020
    Shop #: WSC 01357
    Address 03: ABS Brakes Labels: None
    Address 08: Auto HVAC Labels: 1K0-820-047.LBL
    Part No SW: 1K0 820 047 HM HW: 1K0 820 047 HM
    Component: Climatic PQ35 142 1111
    Address 09: Cent. Elect. Labels: None
    Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
    Component: Bordnetz-SG H54 2602
    Coding: E5890F2700041500471400001400000000087F075C00010000 0000000000
    Shop #: WSC 01357
    Part No: 1K2 955 119 E
    Component: Wischer 011008 021 0501
    Coding: 00038805
    Shop #: WSC 01357
    Part No: 1K0 955 559 AH
    Component: RLS 271008 054 0402
    Coding: 00209069
    Shop #: WSC 01357
    Address 15: Airbags Labels: 1K0-909-605.LBL
    Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
    Component: 38 AIRBAG VW8 020 2300
    Coding: 0013112
    Shop #: WSC 01357
    Address 16: Steering wheel Labels: 1K0-953-549.LBL
    Part No SW: 1K0 953 549 BS HW: 1K0 953 549 BS
    Component: J0527 051 0101
    Coding: 0012022
    Shop #: WSC 01357
    Part No: XXXXXXXXXXX
    Component: E0221 002 0010
    Address 17: Instruments Labels: 1K0-920-xxx-17.LBL
    Part No SW: 1K0 920 974 B HW: 1K0 920 974 B
    Component: KOMBIINSTRUMENT VDD 2416
    Coding: 0003403
    Shop #: WSC 00206
    Address 19: CAN Gateway Labels: 1K0-907-530.LBL
    Part No SW: 1K0 907 530 Q HW: 1K0 907 951
    Component: J533__Gateway H16 0202
    Coding: ED807F060002020003
    Shop #: WSC 01357
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.LBL
    Component: IMMO VDD 2416
    Address 42: Door Elect, Driver Labels: None
    Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
    Component: Tuer-SG 006 1220
    Coding: 0000692
    Shop #: WSC 01357
    Address 44: Steering Assist Labels: 1Kx-909-14x.LBL
    Part No: 1K0 909 144 C
    Component: EPS_ZFLS Kl. 70 2301
    Address 46: Central Conv. Labels: 1K0-959-433-46.LBL
    Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
    Component: KSG PQ35 G2 020 0204
    Coding: 819002005103087F2D04840570085FC690FC00
    Shop #: WSC 01357
    Part No: 1K0 951 605 D
    Component: LIN BACKUP HORN H08 9001
    Part No: 1K0 951 178 A
    Component: Neigungssensor 003 0203
    Component: Innenraumueberw.003 0203
    Address 52: Door Elect, Pass. Labels: None
    Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
    Coding: 0000692
    Shop #: WSC 01357
    Address 56: Radio Labels: 1K0-035-1xx-56.LBL
    Part No: 1K0 035 186 AF
    Component: Radio GR0 036 0034
    Coding: 0040402
    Shop #: WSC 01357
    Address 62: Door,Rear Left Labels: None
    Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
    Component: Tuer-SG 006 1302
    Coding: 0000144
    Shop #: WSC 01357
    Address 72: Door, Rear Right Labels: None
    Part No SW: 1K0 959 704 K HW: 1K0 959 704 K
    Coding: 0000144
    Shop #: WSC 01357
    End --------------------------------------------------------------------------------------------------
  6. Re: Non of the electricals working on the left side of my 2005 mk5 gti
    May 2007
    17 Post(s)
    Quote Originally Posted by richard@thebrae View Post
    Hi and regards to onzarob as I am not trying to contradict him as there may well be different build levels/upgrades ect, but here is a scan of a 2008/2009 mkv match which shows seperate control moduals for the doors, ---
    WOW...did you get vagcom for xmas or what?
    Actually, onzarob is correct. It's the controller in the drivers door that controls all the things that Moeg said aren't working. Even the left rear door electric window (which has it's own control unit) wont work if there is a fault with the controller on the front door. The two control units are linked via a data bus (LIN bus in this case).
    Jim.
  7. Re: Non of the electricals working on the left side of my 2005 mk5 gti
    Kinross Scotland
    Quote Originally Posted by Flash2 View Post
    Jim.
    Hi Jim,
    Sorry my choice of words, that is what I was trying to say in my 1st post above onzarob's post, the central controller being the drivers door modual and the canbus wire going through the door "A" piller grommet being broken or having lost its connection somehow as it carries the message to act.
    As it is the complete left side, it points to a connection, as for two moduals to fail at once does not tally.
  8. Re: Non of the electricals working on the left side of my 2005 mk5 gti
    May 2007
    17 Post(s)
    Hi Jim,
    Yes, I agree. The A pillar connector would defo be worth checking.
    It's just a bit worrying that a VW dealer can't find anything wrong with the car. I'd like to think the dealer would check for a CAN signal at the door control unit. I think that would be the second thing on my list if it came to me for diagnosis.
    Jim.
  9. Re: Non of the electricals working on the left side of my 2005 mk5 gti
    Canada
    I.
    I see you've worked out allot the, you are both right there is controller in both doors, but the drivers door is the master and the passenger the slave.
    As for the door connectors, they are rubbish and prone to letting in damp. They have rubber boot on the which is released by sliding a blade between the body and the boot. then the connector had a latch that is pulled back. chek the see if the connection are poor etc.
    I replace a hole loom in my door to fix one issue. to access the door controller you only need remove the inner panel, to remove the loom the outside door skin has to be removed!!!
  1. ABT Tackles The New Golf GTI
    Last Post: 18-08-2009, 07:50 PM
  2. Please Help Replaced standard Golf MK5 GTI DSG steering wheel for Edition 30 GTI
    By shaft-50 in forum Golf MK5 - 2004 - 2009
    Last Post: 03-06-2009, 09:55 PM
  3. led side lights and number plate lights, not working
    By adamk in forum Audi A3 - Archive Topics
    Last Post: 02-04-2008, 07:37 PM
  4. Volkswagen Unveils Golf Gti W12-650 Design Study
    Last Post: 22-05-2007, 08:24 PM
  5. Replies: 0
    Last Post: 28-10-2006, 05:22 PM
