Thread: Shuddering when brakes applied between 35-45 mph ('02 A6)
Results 1 to 8 of 8
  1. Shuddering when brakes applied between 35-45 mph ('02 A6)
    Mar 2010
    London
    Hi, I have a 2002 A6 1.9tdi estate and have a strange brake problem. When I apply the brakes between 35 and 45 mph the front shudders. This does not happen at any other speed. Has anyone experienced this previously, and if so I would be grateful if anyone knew how to fix it.
    Thanks.
    _sc_
  2. Re: Shuddering when brakes applied between 35-45 mph ('02 A6)
    Mar 2008
    High Wycombe
    Is this shuddering like the ABS is modulating? Or shuddering like the disk is warped / contaminated?
    If it's that the ABS is modulating, then you can check what's happenning by using the measuring blocks in vag-com.
    If it's that the disks are warped (or that there is friction material contaminating the disk), then replace the disks and pads.
    I'm suprised it's only hapenning in such a narrow speed band. Does it shudder at all at higher / lower speed?
    I suppose it could also be caused by wear in the suspension components.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  3. Re: Shuddering when brakes applied between 35-45 mph ('02 A6)
    Mar 2010
    London
    Thanks for your suggestions.
    The discs and pads have recently been replaced (I've just bought the car so I'm not sure whether this was occurring before the disc/ pad change).
    It really only shudders between these speeds. There is a very slight shudder outside this window, but it is very minor and hardly noticeable
  4. Re: Shuddering when brakes applied between 35-45 mph ('02 A6)
    First suspicion is that the new disc making surface was not cleaned property so the disc appear to run out of true and this cuased patch of sheed that when braking modulate the effect. At lower speeds you probabley would not feel it so much and higher speeds will feel more like a vibration. Regards Peter
  5. Re: Shuddering when brakes applied between 35-45 mph ('02 A6)
    May 2009
    Tonbridge
    Cheap discs are a likely cause IMHO, bought a pair on a previous Forester and had shuddering when dropping speed from c 60 mph, but didn't notice at lower speeds below 40 mph. replaced the discs and shuddering was gone.
    Audi A6 4.2 Saloon, Silver
    No mods (yet)
  6. Re: Shuddering when brakes applied between 35-45 mph ('02 A6)
    Sep 2007
    Plymouth
    If you do go down the route of new discs, it is worthwhile making sure the calipers and servo are in good working order first. If they are not tip top the warped disc problem will return.
    2003 A6 1.9TDI PD Avant SE 359,000 miles
    Cannondale Road Bike
    Yeti ASR SL Mountain Bike
    9ft 4inch Surfboard (two of)
  7. Re: Shuddering when brakes applied between 35-45 mph ('02 A6)
    Mar 2008
    High Wycombe
    Just another thought: Have you checked the wheels / tyres for balance and roundness? I know that tyre balance usually makes constant vibrations at higher speed (usually about 60), but it might be adding to the effect.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  8. Re: Shuddering when brakes applied between 35-45 mph ('02 A6)
    Yep could be a tyre or bent rim problem. Regards Peter
  1. Replies: 0
    Last Post: 20-07-2006, 09:08 PM
  2. The New Audi A6 All Road, at home on all roads and tracks
    Last Post: 29-04-2006, 06:00 PM
  3. At home on all roads and tracks - Audi A6 allroad quattro
    Last Post: 05-03-2006, 07:53 PM
  4. New Audi A6 Avant Range Update
    Last Post: 20-01-2005, 10:34 PM
  5. The new Audi A6 Avant
    Last Post: 20-11-2004, 09:09 PM
