Thread: Changing pads on Electric handbrake
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. Re: Changing pads on Electric handbrake
    May 2008
    Quote Originally Posted by martin1810 View Post
    Chris...If you are keeping the car for a few years. Buy genuine VCDS frm ross-tech. You will never regret it. Every time you fault code check your car (or someone else's) you are saving at least £40. It works perfectly and is fantastic value at £260. You get help/support and free upgrades as they come out.
    You can't argue with that - go for it.
  2. Re: Changing pads on Electric handbrake
    Feb 2010
    Caithness
    Thanks very much indeed for the sound advice guys.
    Greatly appreciated indeed!
    Chris
  3. Re: Changing pads on Electric handbrake
    Mar 2009
    What is involved electronically? Can the caliper not be unbolted? Or does the electronic handbrake have to be totally de-activated?
  4. Re: Changing pads on Electric handbrake
    Aug 2009
    leeds
    Got a flyer from my VW dealer today with various prices on it, fitted pads start from £95, Richard Alexander Leeds.
  5. Re: Changing pads on Electric handbrake
    Norfolk
    Quote Originally Posted by Dr. Ferdinand View Post
    The caliper motor has to be completely rewound. Then the caliper piston is pushed in so the pads can be fitted. Once fitted the caliper motor has to be wound back out to the correct starting point for the new pads. This ensures that the caliper motor only winds out enough to put the brake on correctly, when you press the button. If the motor is not reset properly, the brake will either not grip or will push so hard the motor is damaged.
  6. Re: Changing pads on Electric handbrake
    Sep 2017
    Arlington USA
    This is the cheapest only tool that will get it retracted besides that vag com. http://amzn.to/2x6eHdJ It’s a scanner made by autel. You click on the EPB setting pick euorpean, vw , special functions, then deactivate brake, it will rewind the brake piston, turn ignition off. Then you change the brakes as normal. When finished go back to the scanner, same thing and this time activate the brakes instead of deactivate on the scanner. The 12 volt method can cause damage to the ecm
  7. Re: Changing pads on Electric handbrake
    #17
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    87 Post(s)
    Quote Originally Posted by vwmaniac312 View Post
    This is the cheapest only tool that will get it retracted besides that vag com. Amazon.com: Autel MaxiCheck Pro Chassis/Brake/Oil light/Steering Angle Sensor Diagnostic Tool: Automotive It’s a scanner made by autel. You click on the EPB setting pick euorpean, vw , special functions, then deactivate brake, it will rewind the brake piston, turn ignition off. Then you change the brakes as normal. When finished go back to the scanner, same thing and this time activate the brakes instead of deactivate on the scanner. The 12 volt method can cause damage to the ecm
    Which is why you should always connect a battery charger before activating the EPB system when the engine is off. Plenty of small inexpensive hand held EPB brake tools out there most with basic ODB fault scanning capability (not ideal for VW fault code scans where VCDS or equivalently capable more advanced hand held diagnostic tools come in e.g. Autel Maxidiag Elite MD802 / MD805).
    New / Remanufactured TRW caliper and motor units (OE) can be obtained for £150 to £200 each for DIY installation but certainly hugely expensive from VW.
    Mad Mitch
  1. Audi a1 e-tron – zero-emissions in the city
    Last Post: 02-03-2010, 07:54 PM
  2. Audi a1 e-tron – zero-emissions in the city
  3. The Audi e-tron
    Last Post: 02-10-2009, 07:30 AM
  4. The Audi e-tron
    Last Post: 15-09-2009, 08:34 PM
  5. Do you have to slacken handbrake when changing pads?
    By Rog in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-11-2007, 01:09 PM
