Thread: T4 2.5 TDI 1999, loosing water/coolant
  1. T4 2.5 TDI 1999, loosing water/coolant
    Apr 2010
    Collooney Ireland
    Hi, the engine started loosing coolant. No noticeable leak or anything. There is no smoke from exhaust. It looks like its loosing the water/coolant through heating system. Windscreen steams up while driving and smell through heater from engine compartment. Problem seems to get worse. Now I have to replace water every 20 miles. Can anybody give me an idea what is wrong? Thanks! dickums
  2. Re: T4 2.5 TDI 1999, loosing water/coolant
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Heater Matrix leaking.
    Alan.
    VW T6 150 DSG Camper £££
  3. Re: T4 2.5 TDI 1999, loosing water/coolant
    Apr 2010
    Collooney Ireland
    I brought the van to the local garage this morning and they confirmed that the heater matrix is leaking. Is it a big job to change it. They could not tell me.
  4. Re: T4 2.5 TDI 1999, loosing water/coolant
    Nov 2008
    20 Post(s)
    Sorry, not done one on this model, only T5 and they are ok to do, no dash out on them.
    Alan.
  5. Re: T4 2.5 TDI 1999, loosing water/coolant
    Apr 2010
    Collooney Ireland
    Can I disconnect the two hoses to the heater matrix and bridge them temporarily to stop the leakage and then replace the heater matrix? Thanks. dickums
  6. Re: T4 2.5 TDI 1999, loosing water/coolant
    Nov 2008
    20 Post(s)
    Yes you can. And turn the heat control to `cold` also, the coolant will then recirculate as the valve is closed.
    Alan.
  7. Re: T4 2.5 TDI 1999, loosing water/coolant
    Apr 2010
    Collooney Ireland
    Thanks for help Alan. After a job was cancelled this afternoon I decided to become a mechanic. And rather then just taking out the two hoses and bridging them which could end up me driving around like this till next winter came I decided to try and take out the ´leaker´at the same time. Boy did it challenge me (got a helping hand from my local farmer/landlord.. puuh). Now I have a very roomy passenger foot compartment after taking out almost entire heating/ventilation system. Started with pollen filter ended with heater matrix but luckily not the dash. A few hidden screws if nobody tells you and/or you have no handbook. Good it did not require any special tools but took out the the turbo (?) cooler on top of engine in order to get to the clips holding hoses onto the heater. Wish me luck that I get it all together again. Cheers. Dickums
  1. T4 2.5 tdi pump belt non starter!
    By pinklooney in forum The Commercial Range
    Last Post: 12-08-2011, 08:30 AM
  2. Please Help Best Golf for £10k and confusion over different engines?
    By deshg in forum Golf MK5 - 2004 - 2009
    Last Post: 21-09-2010, 07:47 PM
  3. Audi covers new ground with 2010 q7 suv
    Last Post: 15-04-2009, 08:08 PM
  4. Audi takes pole position in TDI diesel development
    Last Post: 01-04-2006, 07:34 PM
  5. New 2.7 TDI Model boosts Audi A6 Saloon range
    Last Post: 24-11-2004, 09:00 PM
