Thread: 1994 Clutch Problem
  1. 1994 Clutch Problem
    Apr 2010
    york
    Hello, I'm having problems with my 1994 Passat. I ogt into the car this morning and passed the clutch pedal down and its now stuck there unless i pull it up by hand. Any answers??? Cheers
  2. Re: 1994 Clutch Problem
    Norfolk
    Clutch master cylinder gone, slave cylinder gone, clutch pressure plate broke, clutch friction plate broke. Take your pick. Could even be a broken pedal arm mounting. watch the slave cylinder on the gearbox when someone presses the clutch pedal. the pedal,. If it don't move the fault is at the pedal/mastercylinder end. If it moves ok the problem is probably the clutch.
  1. Clutch problem
    By didkobandita in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 31-07-2010, 11:32 AM
  2. Choke problem, high clutch, fast idle
    By millyspook in forum Golf MK4 - 1999 - 2004
    Last Post: 04-02-2010, 02:29 PM
  3. A6 Avant 03 plate 2.5tdi gearbox
    By johnm in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 10-06-2009, 06:50 PM
  4. clutch pedal problem
    By FLENG2008 in forum Golf MK4 - 1999 - 2004
    Last Post: 26-08-2008, 09:04 PM
  5. Clutch slave problem?
    By kerrymarkp in forum 80 - 90
    Last Post: 30-05-2007, 01:22 PM
