Thread: Fuel temp sensor
  1. Fuel temp sensor
    Sep 2007
    Liverpool
    Is there a way I can check the fuel temp sensor with vagcom?
  2. Re: Fuel temp sensor
    Aug 2009
    colne
    I think I managed to do this. Even though I have had VAG Com for a couple of years I am still a novice.
    If I remember correctly I went into the engine section and then advanced measuring blocks. In the menu of tick boxes there should be one for fuel temp sensor. On my A6 I got a reading of 77 degrees which I thought was very high but was later told on this forum that it was Okay.
    Hope this helps.................................oh and by the way if you were simply asking if it is possible and you do not have VAG Com the answer would be ....Yes!
  1. Fuel Temperature sensor
    By gazwilson in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 25-03-2010, 10:07 PM
  2. Biodiesel - a summary
    By Huweth in forum Chat - Completely Off Topic
    Last Post: 06-01-2009, 06:25 PM
  3. Touran 1.9TDi Fuel Temp Sensor + EML Light on
    By shairaz1 in forum Touran - Sharan - Caravelle
    Last Post: 26-03-2008, 10:19 PM
  4. Is this the temp sensor?
    By nite in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-11-2007, 03:08 PM
  5. location of temp sensor on 115PD TDI Passat.
    By printman in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-07-2007, 05:56 PM
