Thread: Golf 1.9tdi Plus 55 Plate Fuse Panel?
Page 4 of 4 FirstFirst ... 234
Results 31 to 33 of 33
  1. Re: Golf 1.9tdi Plus 55 Plate Fuse Panel?
    #31
    Nov 2019
    GB
    Lol Not a bad idea with the alarm if that goes...
    The fusebox panel is actually pictured upside down in the manual. (Another punishment for buying a golf plus over a standard golf is these tricks are played on you) I double checked and fuse 23 is a 10 Amp fuse (correct with the picutre) while 47 is not.
    I talked it over with someone and its likely going to be a soleniod/relay which is set in the on position on that fuse side. I have to trace the circuit diagram on that side.
  2. Re: Golf 1.9tdi Plus 55 Plate Fuse Panel?
    #32
    May 2007
    17 Post(s)
    Quote Originally Posted by muscleriot View Post
    Yes, your correct. Fuse 23 is a 10 Amp fuse. A mini blade fuse according to the diagram you posted.
    But it's not the 10 Amp fuse you've highlighted in your photo, because that is a standard blade fuse.
    Look carefully. I've rotated your photo so it matches the fusebox diagram in the manual. The highlighted fuse is 43, which should actually be a 5A fuse.
  3. Re: Golf 1.9tdi Plus 55 Plate Fuse Panel?
    #33
    Jan 2021
    Gloucester, England
    Hi. Super late to this thread but I isolated the parasitic drains on my beloved 1.9TDI Golf Plus (2006) to two fuses (43 and 48), however it does not match up to the standard Golf manual that I have nor the images that have been posted on here. The diagrams on here show that fuse 43 as 30A, whereas it is only 5A in my car, and there are a few other discrepancies. I have attached an image of the darned fuse box in question and the diagram I found on here somewhere. Any help would be greatly appreciated. Thank you.
    Last edited by bastille; 01-01-2021 at 05:27 AM. Reason: additional photos of diagram
  1. new golf estate
    By jcb in forum Golf MK6 - 2009 - 2013
    Last Post: 20-11-2009, 12:36 PM
  2. The scirocco r and golf r now available to order
    Last Post: 03-11-2009, 09:09 PM
  3. The scirocco r and golf r now available to order
    Last Post: 31-10-2009, 09:03 PM
  4. My first impressions of my GT TDi Golf
    By james_tiger_woo in forum Golf MK6 - 2009 - 2013
    Last Post: 30-06-2009, 05:42 PM
