Thread: Golf 1.9tdi Plus 55 Plate Fuse Panel?
Page 4 of 4 FirstFirst ... 234
Results 31 to 32 of 32
  1. Re: Golf 1.9tdi Plus 55 Plate Fuse Panel?
    #31
    Nov 2019
    GB
    Lol Not a bad idea with the alarm if that goes...
    The fusebox panel is actually pictured upside down in the manual. (Another punishment for buying a golf plus over a standard golf is these tricks are played on you) I double checked and fuse 23 is a 10 Amp fuse (correct with the picutre) while 47 is not.
    I talked it over with someone and its likely going to be a soleniod/relay which is set in the on position on that fuse side. I have to trace the circuit diagram on that side.
  2. Re: Golf 1.9tdi Plus 55 Plate Fuse Panel?
    #32
    May 2007
    13 Post(s)
    Quote Originally Posted by muscleriot View Post
    Yes, your correct. Fuse 23 is a 10 Amp fuse. A mini blade fuse according to the diagram you posted.
    But it's not the 10 Amp fuse you've highlighted in your photo, because that is a standard blade fuse.
    Look carefully. I've rotated your photo so it matches the fusebox diagram in the manual. The highlighted fuse is 43, which should actually be a 5A fuse.
  1. new golf estate
    By jcb in forum Golf MK6 - 2009 - 2013
    Last Post: 20-11-2009, 12:36 PM
  2. The scirocco r and golf r now available to order
    Last Post: 03-11-2009, 09:09 PM
  3. The scirocco r and golf r now available to order
    Last Post: 31-10-2009, 09:03 PM
  4. My first impressions of my GT TDi Golf
    By james_tiger_woo in forum Golf MK6 - 2009 - 2013
    Last Post: 30-06-2009, 05:42 PM
