Thread: Different help with a Tiptronic.
Results 1 to 10 of 10
  1. Different help with a Tiptronic.
    Feb 2010
    United Kingdom
    Hi all,
    I have had my s4 avant tip for a few days now, and i have a couple of questions!
    When driving normally in D, around 30-40mph, it seems to stay in 4th gear until i speed up a little, but then only really changes up from 5th as speed increases. If i am cruising along at around 30 and let off the throttle, it doesnt change up. I read in the manual that it would change up through the gears fairly quickly (unless using kickdown) for economy. A friend of mine has a B6 S4 tip and his doesnt seem to "hang" in 4th at low speeds.
    And, when pulling up to a junction, it doesnt drop down into first to pull out, it stays in 2nd, unless i accelerate a little quickly, and then it kind of jerks down into first almost instantly, and then im away. Its not a problem as such, just seemed a bit odd!
    Is this normal behaviour with the tip tronics?
    As i say, my buddy who (i thought) had exactly the same engine and gearbox doesnt have these issues(?).
    Have they modified any gearbox softwares for the b7 from the b6?
    Any help much appreciated before i go back to the dealer.
  2. Re: Different help with a Tiptronic.
    Apr 2009
    Hi, I think what is happening is that the car is using the lowest possible rpm to save gas, I have the same car (B7) and always has this slow response, to avoid this you can use the sport mode or just chip the car with a different setup.
  3. Re: Different help with a Tiptronic.
    Feb 2010
    United Kingdom
    Thanks for that.
    Does yours stay in 4th at around 30-40mph?
    I thought they changed up fairly quickly as another economy "thing:.
  4. Re: Different help with a Tiptronic.
    Apr 2009
    Not sure if is the 4th but I notice that the RPM are always in the 2000 range, the turbo is not responding at that range, I will pay attention today in my way home to see if that is happening. Will post later
  5. Re: Different help with a Tiptronic.
    Feb 2010
    United Kingdom
    Brill thanks.
  6. Re: Different help with a Tiptronic.
    Southern County Softy
    20 Post(s)
    Quote Originally Posted by Meteoro View Post
    Don't think Jasons S4 will have a turbo....
    @ Jason have you checked the transmission fluid ?
    A4 2.5 tdi QS (mapped)
  7. Re: Different help with a Tiptronic.
    Feb 2010
    United Kingdom
    No i havent a turbo.
    And no i hadnt even thought about checking the fluid as i have just bought it used from an Audi dealer, and so i assmumed all this would have been part of the multipoint check?
  8. Re: Different help with a Tiptronic.
    20 Post(s)
    If you have just brought and are not happy with something....take it back and have them look at the problem under the warranty
  9. Re: Different help with a Tiptronic.
    Apr 2009
    Hi, well without a turbo, this will make a big difference, we have different engines and we can't compare the transmissions. My opinion is the same as kite, go back to the dealer and explain the problem.
  10. Re: Different help with a Tiptronic.
    Nov 2006
    Southampton
    Jason S
    No multipoint check will pick up transmission fluid, in Audi world they are sealed for "life"
    Get it changed I didn't and £4300 later...
  1. Replies: 4
    Last Post: 20-08-2010, 11:31 PM
  2. 3.2 fsi tiptronic
    By allytt in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 27-05-2010, 09:36 PM
  3. 2003 2.8 V6 4Motion Tiptronic problem
    By limecc in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-12-2009, 10:05 PM
  4. Question Tiptronic....yes or no?...any problems?
    By darich in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-08-2009, 12:32 AM
  5. At home on all roads and tracks - Audi A6 allroad quattro
    Last Post: 05-03-2006, 07:53 PM
