Thread: Central Locking Problem
Results 1 to 8 of 8
  1. Central Locking Problem
    Jan 2010
    York, UK
    A central locking problem seems to be a common problem with these cars, and mine is no exception- the central locking doesn't work!
    After much tinkering, fiddling and inspection, I have determined that:
    • The graphite blades are intact
    • The electric motor works (while detached from module and powered separately)
    • No leaks exist in the hoses
    • The module "clicks" when the key is turned in any of the locks and in either direction.
    I am at a loss to find an answer, and wonder if anyone has any thoughts on this?
    Thanks,
    Gareth
  2. Re: Central Locking Problem
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Try feeling for a Vacuum at the outlet of the pump, on locking. Pressure on opening. Maybe a problem where the pipes go.
    Alan.
    VW T6 150 DSG Camper £££
  3. Re: Central Locking Problem
    Jan 2010
    York, UK
    Unfortunately there is nothing.
    I have been able to operate the locks this morning by blowing down the pipe.
    Gareth
  4. Re: Central Locking Problem
    Nov 2008
    20 Post(s)
    You say module clicks when key operated in lock,but does the pump cycle?
    Alan.
  5. Re: Central Locking Problem
    Jan 2010
    York, UK
    The module clicks however the pump does not operate.
    Exactly the same symptoms from another module I borrowed this afternoon.
  6. Re: Central Locking Problem
    Nov 2008
    20 Post(s)
    It may be missing a signal / feed from somewhere. May need a wiring diagram to check at pump. Have you checked the loom from drivers door to A-Pillar?
    Alan.
  7. Re: Central Locking Problem
    Jan 2010
    York, UK
    Hi Alan02,
    Thanks for your help with this. Where is the wiring loom positioned through the vehicle and where can I find a wiring diagram?
    Gareth
  8. Re: Central Locking Problem
    Nov 2008
    20 Post(s)
    Hi Gareth,
    The wiring from each door lock runs through the rubber sheath that goes from the inner edge of door to the area where the hinges are fixed.Wiring diagram a bit harder,Haynes perhaps ?
    Alan.
  1. Audi 80 Central Locking Problem
    By tp5harp in forum 80 - 90
    Last Post: 20-05-2010, 09:30 PM
  2. Please Help Central Locking Problem
    By MBEN in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-03-2010, 08:48 PM
  3. Problems connecting Remote Central Locking ...2004 Polo E
    By andy4976 in forum Polo - Derby - Lupo - Fox
    Last Post: 29-06-2009, 10:24 AM
  4. A4 Central locking
    By gre22 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-01-2008, 03:08 PM
  5. Bizarre Central Locking problem
    By swiss_steve in forum Beetle 2000-
    Last Post: 14-03-2007, 09:21 PM
