Thread: Another problem with my 80tdi
  1. Another problem with my 80tdi
    Mar 2007
    J27 M5
    Right then, yesterday all was well, started with no smoke or anything ran fine, today get in it turn key fires up but white smoke and ecu lights on
    Any ideas
    There is no air in the fuel, there is no low compression, the headgasket is brand new, glow plugs are all working
    Things I do : Engine Swaps, Modifications, Car Audio Installs
    Things I dont do : Diesels
    Nov 2006
    To be honest... white smoke is generally from water getting in to the system... so generally a coolant leak internally. If there is really alot, then thats the problem I'm thinking. Is the head torqued down properly? I didn't catch why the head gasket is new... but if it blew before, sometimes you have to skim the head as it can warp a tiny bit and not give a good seal. Unfortunately retorquing the head if the gasket has started leaking generally rarely works. You may have to remove the head, have it skimmed and get a new gasket unfortunately.
    (but this is just my impression from your short post - would definitely be nice if it this wasnt the problem).
    Brd.
  1. Newbie with 93 80tdi performance issues
    By Ryan80 in forum 80 - 90
    Last Post: 11-04-2007, 09:44 AM
  2. audi 80tdi belt tensioner
    By littlekev in forum 80 - 90
    Last Post: 17-02-2007, 03:51 AM
  3. Audi 80tdi sewing machine
    By simyboye in forum 80 - 90
    Last Post: 26-01-2007, 07:45 PM
