Thread: TDI glowplug "Open Circuit" fault code
  1. TDI glowplug "Open Circuit" fault code
    Sep 2007
    Bookham, Surrey
    Hi - anyone know what the fault codes below mean about an Open Circuit on two of the glowplugs. Car has been running fine but I notice these faults show up from time to time.
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 4F0 910 402 S HW: 4F0 907 401 C
    Component: 3.0L V6TDI G000AG 0020
    Revision: --H03--- Serial number:
    Coding: 0011372
    Shop #: WSC 66565 257 00032
    2 Faults Found:
    005658 - Glowplug for Cylinder 1 (Q10): Open Circuit
    P161A - 001 - Upper Limit Exceeded
    Freeze Frame:
    Fault Status: 01110001
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 120865 km
    Time Indication: 0
    Date: 2010.03.01
    Time: 22:13:36
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 11.86 V
    Duty Cycle: 15.0 %
    Temperature: 30.6∞C
    005659 - Glowplug for Cylinder 2 (Q11): Open Circuit
    P161B - 001 - Upper Limit Exceeded
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 120865 km
    Time Indication: 0
    Date: 2010.03.01
    Time: 22:13:36
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 11.86 V
    Duty Cycle: 15.0 %
    Temperature: 30.6∞C
    Readiness: 0 0 0 0 0
  2. Re: TDI glowplug "Open Circuit" fault code
    Sep 2007
    Bookham, Surrey
    I see the following info on the Ross-Tech wiki - anyone else had the fault on their car? What did you do?
    P161B/005659 - Glowplug for Cylinder 2 (Q11): Open Circuit
    Possible Symptoms
    Malfunction Indicator Light (MIL) active
    Possible Causes
    Glowplug for Cylinder 2 (Q11) faulty
    Automatic Glow Time Control Module (J179) faulty
    Possible Solutions
    Check Glowplug for Cylinder 2 (Q11)
    Check Wiring/Connectors from/to Glowplug for Cylinder 2 (Q11)
    Check Automatic Glow Time Control Module (J179)
  1. cruise/dis retrofit programming help
    By jetbox in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 24-12-2009, 07:12 PM
  2. 2003 abs & steering angle recode need help
    By deutsch in forum VCDS - General Questions
    Last Post: 28-11-2009, 12:34 AM
  3. Intense TDI power - The Audi A3 TDI clubsport quattro
    Last Post: 18-05-2008, 10:12 AM
  4. 05 Audi A4 2.0 TDI problems
    By Dent Reform in forum VCDS - General Questions
    Last Post: 12-05-2008, 09:18 PM
  5. New 2.7 TDI Model boosts Audi A6 Saloon range
    Last Post: 24-11-2004, 09:00 PM
