Thread: DIY Alloy Restoration...
  1. DIY Alloy Restoration...
    Mar 2009
    York
    By chance, has anyone here attempted DIY repairs on peeling/damage to your Passat's alloy wheels?
    I have a few unslightly scrapes that have damaged the coating (and therefore are peeling), plus one that is starting to cause a 'spidering' effect, working its way under the laquer.
    I've researched and noted the Wurth German Alloy Respray/Lacquer sprays, which apparently match quite well the colour of VW alloys, and intend to sand-down, fill and respray these (small) areas on my wheels.
    I'm not likely to be doing anything until the weather warms up (for better spraying/drying time), but feel that this is a better option rather than let them get any worse, and therefore have to get new alloys instead...
    paul.
    A3 8V S-Line Cabriolet 2.0 TDI
    Passat B6 FSI • Passat TDI 105 • BMW E90 318d • BMW F30 320d Lux
  2. Re: DIY Alloy Restoration...
    7 Post(s)
    I've done this quite a few times with good results.
    In fact my latest go was only last week!
    Not on a VW but....
    Quite easy to with the tyres off and quite do-able with them on only that you obviously have to mask off.
    As an alternative to the Wurth paint, Fords Moondust silver is a good cheaper match.
    The trick as with any cellulose spraying to getting a goof finish is in the polishing up afterwards. If you need any tips, then just ask.
  3. Re: DIY Alloy Restoration...
    Mar 2009
    York
    looks like a great job done there..
    although i won't have the luxury of being able to remove the tyres, I will be able to mask off the areas that need work doing. The only slight difference may be in the final look - on close inspection, the finish of the alloys on mine are like machined steel, very similar to a vinyl record. Obviously with the silver paint it will be more of a metallic finish - however as long as the colours are similar, no-one's going to get that close to inspect them...
  4. Re: DIY Alloy Restoration...
    7 Post(s)
    You will need to re-finish the whole of the face of the wheel to make it look right.
    Masking off the tyre isn't so bad just takes a little time. Also mask off the rear of the wheel as well if your not re-finishing both sides as the overspray will look messy and is a right sod to remove.
  5. Re: DIY Alloy Restoration...
    Jun 2008
    I've used the wurth stuff before on BMW alloys and it's a good match and good quality paint.
    It's all about the prep with this kind of job
  6. Re: DIY Alloy Restoration...
    May 2008
    Quote Originally Posted by patomlin76 View Post
    This finish is often referred to as 'diamond' cut finish. In reality it can be a pretty rough finish, although looks good if machined correctly. Attached is a picture of one I did recently from a Mercedes AMG.
  7. Re: DIY Alloy Restoration...
    Mar 2009
    York
    OK, so I don't want to respray the whole wheel (or all 4 if the diamond cut finish looks different on the other 3 wheels), so is there any touch-up paint that closely matches our alloys? Just thinking that I may just cover the chips with a close matching colour that looks OK from a distance - I'm talking an area of around 3-4mm2, so any close matching silver would do...
    thanks.
  1. Replica Alloy Wheels
    By sooty in forum Chat - Anything with wheels
    Last Post: 24-09-2009, 09:09 AM
  2. alloy refurb DIY??
    By luko in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 28-08-2009, 12:19 PM
  3. Yesterday afternoon
    By Andy J in forum Chat - Completely Off Topic
    Last Post: 28-07-2009, 09:50 AM
  4. Replies: 0
    Last Post: 01-08-2007, 08:28 PM
  5. Alloy Advice Needed.
    By Studio54 in forum Passat - Archive Topics
    Last Post: 20-10-2006, 06:20 PM
