Thread: cam adj seal
  1. cam adj seal
    Jun 2008
    Hi all, think i need to replace my cam adjuster seal on my a4 b5 1.8 20v non turbo apt engine, have oil leaking very slightly from that sort of area, have replaced valve cover gasket, looked at breather hoses etc and still have this problem. oil smell from inside car, oil lying on heatshield on left of engine( facing front) cleaned the suspected area where cam seal is and looks oily again and i think its getting worse, getting to point is it reasonbly easy or does it involve lifting out camshafts etc. part itself only 6 to buy from audi, any advice much appreciated cheers billy.
  2. Re: cam adj seal
    Jan 2009
    towcester northants
    camshafts have to be lifted a bit to allow the adjuster to get clearance
  3. Re: cam adj seal
    Jun 2008
    hi, its the half moon seal i want to replace, is it just a case of lifting one end of camshaft and taking out half moon seal and pop in the new one, noticed there was another part that comes with the seal, looks like a c spanner.
    cheers billy
  4. Re: cam adj seal
    Jan 2009
    towcester northants
    change it all
    lift up cam and slip into place its a bit fiddly and you need a tool to compress chain tensioner
  1. Oil leaking after cam belt change - help!
    By benr77 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 18-11-2009, 04:26 PM
  2. Guide S4/A4 V6 Cambelt
    By spellmaster in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-10-2009, 05:23 PM
  3. "How to" Repair cam of O2A 945 413 reverse switch
    By imortalmonkey in forum Volkswagen
    Last Post: 03-05-2009, 09:30 AM
  4. Golf Cabriolet 1999 door seal
    By mjay in forum Golf MK4 - 1999 - 2004
    Last Post: 26-01-2008, 11:56 AM
  5. Golf III 1Y 1.9 diesel - Cam seal Material ?
    By golfiii1y in forum Archive posts
    Last Post: 12-07-2007, 10:58 PM
