Thread: Electrical Issue, I think?
  1. Electrical Issue, I think?
    May 2008
    Hi All,
    Sorry to be a pain but been trying to get to the bottom of an issue for the last week!
    Basically when i turn right the indicators flash at a very high speed, so though ok either a fuse or bulb has gone, checked the every fuse and all ok, checked bulbs and the rear bulb was not flashing so brought some new ones and replace the rear bulbs and it is still not working and cannot figure out why??
    whilst running around the car i have now noticed that the cigerette lighter does not work even tho the fuse is fine and the speakers in the drivers door seem to only come on now and then or if i put the volume up or give them a smack
    can anyone help with any of this as the car is now starting to have more problems than its worth ( sync mesh has gone in 3rd)!!!
    thanks
    Andy
  2. Re: Electrical Issue, I think?
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    Andy , the high speed flashing is a bulb as you rightly say, if you swapped the bulb for a known good one then check and clean the holder to ensure a decent connection.
    Cigarette lighters can just go dead but again check out the wire/plug connections to the unit
    Speaker again check for loose or dirty connection
    Stuart
  1. B5 Passat Electrical issue
    By gubee in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-03-2010, 10:48 PM
  2. Please Help Heating Issue with 2000 Passat no warm air at high blower speed
    By mafia666 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-03-2010, 08:46 PM
  3. Weird Multitronic issue
    By Seanious in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 10-11-2009, 04:57 PM
  4. Please Help Intermittent total electrical failure
    By grumpypanda in forum Alhambra
    Last Post: 29-07-2009, 04:51 PM
  5. 2002 1.8T 150BHP GTI Exhaust/Turbo Noise Issue
    By joshtomlinson in forum Golf MK4 - 1999 - 2004
    Last Post: 28-01-2008, 11:04 PM
