Thread: Distributor setting
  1. Distributor setting
    Mar 2010
    Port Pirie Australia
    Do I need to short out the distributor in order to return it to it's static timing setting so I can set the cam timing correctly, how do I short it?
  2. Re: Distributor setting
    You will have to translate matey,and you can start by telling us,what type of vehicle,and the engine code,and what you mean by short it
  3. Re: Distributor setting
    Mar 2010
    I have a 2000 model transporter, 2.5 ltr 5 cyl petrol, By short out I mean do I need to earth a wire from the distributor to be able to set the timing....
  4. Re: Distributor setting
    The engine must be put into basic setting,you can then use a stroboscope.the TDC mark O is on the flywheel (accessed through the hole on top of the gearbox) Setting figure: 6 ± 1° before TDC,
  5. Re: Distributor setting
    Mar 2010
    Thanx Kenney, I sorted it and put around 700 k's on the old girl over the weekend, she ran smooth as new....
