Thread: 2002 Polo 1.9 TDI lack of acceleration power?
Results 1 to 10 of 14
  1. 2002 Polo 1.9 TDI lack of acceleration power?
    Mar 2010
    Bfd.
    I've only recently bought the car but here goes. The airbag light won't go out, a couple of times the car has beeped at me and flashed up the Electro-Hyrdaulic Steering light and the Handbreak light at the same time. It also beeps at me everytime I turn the ignition to start the car?
    I was advised to put it on a computer and the man said it could be the alternator?!
    It seems like when I start the car, it's willing to go, then after a while it struggles to accelerate.
    Help!
  2. Re: 2002 Polo 1.9 TDI lack of acceleration power?
    Jan 2009
    towcester northants
    unlikely alt
    get steering ecu checked as these do fail
    diag test airbag ecu for fault
    check engine ecu for faults
  3. Re: 2002 Polo 1.9 TDI lack of acceleration power?
    Mar 2010
    Bfd.
    cheers for the quick reply, when you say check the ecu for airbags etc, do they have their own ecu or are they part of the main ecu?
    excuse my ignorance!!
  4. Re: 2002 Polo 1.9 TDI lack of acceleration power?
    Aug 2008
    Wigan
    9 Post(s)
    Just a thought, are your brake lights working? Failed brake light switch/bulbs can cause all sorts of error messages. The switch costs £9.55 at main dealer and is easy to fit. Bulbs are a bit of a pain, the light unit has to come off but it's not too bad - bulb is stop/tail 5/21W type.
    Re lack of power see this post:- https://www.vwaudiforum.co.uk/forum/s...ad.php?t=94233. It's Golf related but may help.
  5. Re: 2002 Polo 1.9 TDI lack of acceleration power?
    Mar 2010
    Bfd.
    All the lights are fine man, and the switch is working ok too. I'm taking it back to the computer guy and he's gonna write all the codes down me, ill post em back up when I get chance to go.
    Top banana.
  6. Re: 2002 Polo 1.9 TDI lack of acceleration power?
    Mar 2010
    Bfd.
    17964 Charge Pressure Contr. Negative Deviation
    17911 Load signal from Alternator Term. DF Range/performance/Incorrect Signal
    18044 Data Bus Powertrain missing message from Airbag control
    18056 Data Bus Powertrain Malfunction
    18061 Please check DTC Memory of ABS Control Module
  7. Re: 2002 Polo 1.9 TDI lack of acceleration power?
    Mar 2010
    Bfd.
    Upon closer inspection, the hose that connected to the intercooler was off! Back to full power, still need to resolve the break / air bag issues.
  8. Re: 2002 Polo 1.9 TDI lack of acceleration power?
    Jan 2009
    towcester northants
    data bus faults could be caused by a voltage fault
    load signal from alternator could be due to battery going too low
    check the alternator freewheel pulley to see if its ok
    cancell faults and recheck
  9. Re: 2002 Polo 1.9 TDI lack of acceleration power?
    Mar 2010
    Bfd.
    Quote Originally Posted by lukepolotdi View Post
    Upon closer inspection, the hose that connected to the intercooler was off! Back to full power.
    Counted my chickens too soon, when i tried to go up a hill it went limp again! Nightmare. Will try do the wd40 trick with the actuator, if thats not it then ill try the AMM! oh dear oh dear.
  10. Re: 2002 Polo 1.9 TDI lack of acceleration power?
    Mar 2010
    Bfd.
    Quote Originally Posted by towcestervag View Post
    I'll put the multimeter on it and see what its gettin. I'll also put the battery charger on and try boost that up too.
    Pulley seems ok, belt is nice and tight.
    Cheers, for your advice will let you know.
  1. Replies: 38
    Last Post: 08-06-2021, 07:43 AM
  2. Please Help Best Golf for £10k and confusion over different engines?
    By deshg in forum Golf MK5 - 2004 - 2009
    Last Post: 21-09-2010, 07:47 PM
  3. lack of power 2000 1.9 TDI A4
    By Maclain in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-09-2009, 05:35 PM
  4. Intense TDI power - The Audi A3 TDI clubsport quattro
    Last Post: 18-05-2008, 10:12 AM
  5. No power until 2500 RPM 1.9 TDi
    By unclealbert in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 29-07-2006, 02:20 PM
