Thread: Polo 9N Fault Code 17961
  1. Polo 9N Fault Code 17961
    buckinghamshire
    This fault relates to a 1.4L Polo BBY engine. The fault code is 17961 Barometric/Manifold Pressure Signals : Implausible Correlation. P1553 -35 -10 Intermittent. The car runs OK although a little noisy when cold.
    Could any experts out there let know what the probable cause of the problem is ? Many thanks
  2. Re: Polo 9N Fault Code 17961
    Jan 2009
    towcester northants
    you need to check the maf sensor readings to confirm
    poss maf sensor or camtiming out or throttle body reqs clean out and reset
  3. Re: Polo 9N Fault Code 17961
    Mar 2010
    notts u.k
    hi check the timing belt tensioners they are plastic coated and the plastic coating can come off which puts the timing slightly out causing a code i have seen 2 in the last year on V.W 1.4 16v engines with this problem although i cannot remember what code it was that they had but may be worth a look and might save you many hours of head scratching.
  4. Re: Polo 9N Fault Code 17961
    Bradford
    Sorry to drag an old thread up, ive got the same issue. Wifes polo comes up with the following code.
    Address 01: Engine Labels: 036-906-034-APE.lbl
    Part No: 036 906 034 KA
    Component: MARELLI 4TV 7448
    Coding: 00071
    Shop #: WSC 00000
    VCID: 5BBF89B5C93EA11
    WVWZZZ9NZ6Y178787 VWZ7Z0E2811296
    1 Fault Found:
    17961 - Barometric / Manifold Pressure Signals
    P1553 - 35-00 - Implausible Correlation
    Readiness: 0110 0101
    Any idea, or should i follow whats been posted above, throttle body, timing belt tensioners.
  5. Re: Polo 9N Fault Code 17961
    buckinghamshire
    The car at the start of the thread was my son in laws car. A little while after this he booked it into a VW dealership for an MOT and when he got it back I noticed that the hose from the inlet manifold to the brake vacuum reservoir had been replaced (at no charge). Perhaps this was the cause of the problem. The car now belongs to someone else but is still running albeit with horrendous piston slap, particularly when cold, and big end rattle when hot. Best of luck with yours!
  1. dpf fault
    By deutsch in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 09-03-2010, 02:50 PM
  2. Volkswagen announces prices for new polo as car goes on sale
    Last Post: 10-08-2009, 09:47 PM
  3. Replies: 6
    Last Post: 13-05-2009, 05:20 PM
  4. Check my scan
    By kite in forum VCDS - General Questions
    Last Post: 11-05-2009, 08:03 PM
  5. Please Help Climatronic Fault Code.
    By gbdxo in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-04-2009, 04:49 PM
