Thread: 1.6 SE Cooling issue
  1. 1.6 SE Cooling issue
    Norwich
    Hi all.
    Recently replaced the thermostat as it had failed. Car was running cold. Car was running fine at 90 degrees for the last couple of months. Now it's running cold again!
    Apart from the new thermostat becoming faulty, which is possible, would anything else cause the car to run cold?
    Tbonetone.
  2. Re: 1.6 SE Cooling issue
    Mar 2010
    london
    Did you buy the thermostat yourself??? if so was it a genuine or rubbish copy part???
    Would change it again and try and flush your water system at the same time... The deposit of dirt could be an adding factor to your thermostat going so quickly...
  3. Re: 1.6 SE Cooling issue
    Norwich
    It was an eBay product but a QH one. I've used QH for years on various cars and they never seem to fail this quickly.
    I'll give it a go as the car seems to be running fine so I can't think of anything but this either
    Cheers for the response.
    T
  1. Replies: 0
    Last Post: 23-01-2010, 07:00 PM
  2. Škoda Octavia 1.2 TSI and 1.6 TDI CR DSG: Two More Reasons to be Happy
  3. Touran Cooling Fans and 'Intake manifold flap motor problem?
    By Matt B in forum Touran - Sharan - Caravelle
    Last Post: 02-10-2009, 01:09 PM
  4. '97 Cab thermostat cooling fan issue
    By BobC in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 23-05-2009, 04:20 PM
  5. VW Golf 1.6 Mark 4 - cooling fan issue?
    By powara in forum Golf MK4 - 1999 - 2004
    Last Post: 19-12-2007, 08:08 PM
