Thread: water problems
  1. water problems
    Mar 2008
    South Africa
    Hi Friends,
    Its Dave again with my 1989 Audi 100 type chassis. Unusual water problem?
    If I ensure the water is topped up before a long trip (250 Kms ) it does not use any water. On short trips around town I have to top up the water every two weeks. ( About 2 cups .) However sometimes on a long trip I can only go about 30 Kms and the warning light comes on, and I have a very hot engine. If I then wait until the engine is cool and then top it up again I can travel many Kms without any more water problems. It seems to be an intermittent problem?
    I know this is not a serious problem but I wonder why this should be. I always use anti-freeze as its supposed to lubricate and keep water cooler in summer. The temperature gauge indicates about 90 degrees "C" when hot.
    I do not want to add "Radiator leak" as I don not believe it is the radiator. I somehow feel it may be a water valve problem?
    Thank you for your comments and suggestions!
    Regards,
    Dave
    surgeon
  2. Re: water problems
    Dec 2007
    8 Post(s)
    Quote Originally Posted by Dave Alexander View Post
    Hi Friends,
    Regards,
    Dave
    Two possible points where water leaks develop are the plastic type water connectors that are bolted to cylinderhead,only cure when these leak is replacement. The water pump can also develop intermittent water leak
    If the engine tray is still fitted it is difficult to determine leaks as the water
    evaporates from the connectors on a hot engine. I find it is easier to locate water leaks on a cold engine. The fact that sometimes you only get 30 kms
    before problems may point to faulty thermostat. try the simple things first
  3. Re: water problems
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Try removing the undertray after a run and laying cardboard down and see if over time a leask appears.I have known water pumps to only leak once the system pressure drops,but also,as mentioned,an `o` ring or hose could be leaking too.
    Alan.
    VW T6 150 DSG Camper £££
  4. Re: water problems
    Mar 2008
    South Africa
    Many thanks ALAN02. I will check these things this week end and let you know what I find.
    Regards,
    Dave.
    surgeon
  5. Re: water problems
    Mar 2008
    South Africa
    Many thanks Micheal, I will check these things out this weekend which happens to be a long weekend. I will let you both know what I find.
    Kind regards,
    Dave.
    surgeon
  6. Re: water problems
    Sep 2007
    Hello Dave
    Had a similar problem many years ago on a turbo diesel passat. Turned out to be a loose impeller on the waterpump. Long motorway trips no probs.......round town overheated.
    Just a thought!
    cheers steve
  1. water in drivers side footwell
    By baj25 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-05-2010, 04:48 PM
  2. water leak has caused me problems!!
    By onewaynebiggins in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-02-2010, 07:46 PM
  3. Attention water temp problems
    By bingsgttdi in forum Golf MK4 - 1999 - 2004
    Last Post: 08-10-2009, 11:30 PM
  4. Water Loss Problems
    By choppersmurf in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 29-06-2007, 07:00 PM
  5. GOLF..PROBLEMS AFTER WATER.......
    By RickT in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 31-12-2006, 09:24 PM
