Thread: slight brake pedal vibration - warped discs?
  1. slight brake pedal vibration - warped discs?
    May 2008
    Howdy.
    I have a 51 Bora 115ps, 105k miles. Over the past few months I've noticed feedback through the brake pedal - like a mild version of ABS. It's noticeable when I am braking gently over say 50 yards or more. Doesn't seem to be getting worse. Braking efficiency is fine. No warning lights, and the pads / discs don't look particularly worn (although about 9 months ago my garage said that one of the discs had a crack in it and should be replaced but I couldn't see which or where, so no action taken. The discs and pads are no more than 4 years old, and done no more than 25k miles).
    Should I be thinking of replacing the discs and pads, or just discs or pads, or simply leaving as is?
    Probably not connected, but about 6 months ago I had a couple of new tyres which involved switching wheels around. I got the feeling the fitter was a bit of a cowboy outfit. Perhaps they didn't refit the wheels with the right torque?
    Also probably not connected, but the tyre fitters said the track rod ends needed replacing at the next service and tracking re-checking (I had to replace the front tyres 'cos they were bald on the inside.... grr - 2nd time that has happened to me).
    Thanks for any advice, sorry for the long post!
    viva la Bora
  2. Re: slight brake pedal vibration - warped discs?
    Replace the track rod,if the vibrating continues,you will need to replace both discs and pads
  3. Re: slight brake pedal vibration - warped discs?
    May 2008
    Hi Kenney
    Thanks for the response. Inevitable question: how much am I looking at for a new track rod?
    Many thanks
  4. Re: slight brake pedal vibration - warped discs?
    tie rod end from BASIC GERMAN PRICELIST 27.6 Euro + 1 hour labour
  5. Re: slight brake pedal vibration - warped discs?
    May 2008
    a pleasant surprise!
    thanks for your help
  6. Re: slight brake pedal vibration - warped discs?
    gretna
    Quote Originally Posted by lfnfan View Post
    Has it solved your problem?
    I have got same symptons now....
  7. Re: slight brake pedal vibration - warped discs?
    May 2008
    Hi roypaci
    took my car for its service on thursday just past - they examined the track rod and ends and found slight play. advised cause of vibration was not track rod but badly worn discs & pads (had been telling me to replace discs & pads for past 1.5 years...). Replaced front discs & pads (£200), and breaks smooth as butter now.
    hth
  1. "How To" Front brake pad/disc replacement
    By bora(ing) nick in forum Volkswagen
    Last Post: 24-06-2011, 12:05 PM
  2. Brake pedal sensor intermittent...
    By JohnW78 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-12-2009, 11:43 AM
  3. Wishbone Front / Rear Axle Bush which brand
    By MathewRB in forum Golf MK4 - 1999 - 2004
    Last Post: 23-05-2009, 12:27 AM
  4. can i have some bleeding help please?
    By darkhorse1001 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-01-2008, 05:42 PM
  5. What Brakes
    By Tonka73 in forum Passat - Archive Topics
    Last Post: 08-01-2007, 01:11 PM
