Thread: Central Locking Problem
  1. Central Locking Problem
    I have a 2001 130 TDI estate which has developed a problem with the central locking. It unlocks fine (every time) using the fob but will only lock intermittently via the fob, every thing works well using the key in the lock.
    I have tried the spare key with the same results so rule this out, which to my mind leaves the central locking unit in the door or the CCM in the passengers footwell, I suspect the former but would appreciate thoughts before start taking things apart.
    Thanks, MBEN
  2. Re: Central Locking Problem
    Norfolk
    If only one door is involved it is more likely to be the door control unit or wiring from the ccm to the door control unit. This doesn't mean it is not the ccm playing up though. A fault code read will sometimes help by telling you that the ccm can't communicate with the door control module. That then suggests a wire or door module problem.
  1. Audi 80 Central Locking Problem
    By tp5harp in forum 80 - 90
    Last Post: 20-05-2010, 09:30 PM
  2. Central locking problem 2002 bora
    By beerboy in forum Bora - 1998 - 2005
    Last Post: 12-10-2009, 08:05 PM
  3. Problems connecting Remote Central Locking ...2004 Polo E
    By andy4976 in forum Polo - Derby - Lupo - Fox
    Last Post: 29-06-2009, 10:24 AM
  4. A4 Central locking
    By gre22 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-01-2008, 03:08 PM
  5. Bizarre Central Locking problem
    By swiss_steve in forum Beetle 2000-
    Last Post: 14-03-2007, 09:21 PM
