Thread: Fault code 05465 on Golf
  1. Unhappy Fault code 05465 on Golf
    Mar 2010
    Epsom UK
    Hi
    Any ideas on what fault code 05465 is? Garage said this was the cause of the engine management light coming on but they couldn't find the code in their code books, etc. So I am stuck! Car runs fine and is a 2005 VW Golf 1.4 FSI with 43k on the clock.
  2. Re: Fault code 05465 on Golf
    1840 Post(s)
    05465 (P1559) Throttle valve control part -J338- Fault in basic settings
    Remove, clean and readapt the throttle body in Basic Settings 060.
    What is your engine type code, BKG?
  3. Re: Fault code 05465 on Golf
    Mar 2010
    Epsom UK
    As far as I can tell it is a BLN(?)
    When you say readapt it, do you mean that the basic settings have to be re-input by the garage?
  4. Re: Fault code 05465 on Golf
    Mar 2010
    Epsom UK
  5. Re: Fault code 05465 on Golf
    1840 Post(s)
    Yes, sort of. After cleaning the throttle body, it must be readapted to the ECU using a diagnostic computer in Basic Settings 04, Main Group 060, wait 30 seconds, exit basic Settings, exit engine 01, turn off the ignition, wait 30 seconds and then turn on and re-start, the code should clear on its own or at least if instructed to clear.
  1. dpf fault
    By deutsch in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 09-03-2010, 02:50 PM
  2. Healp needed VAG com
    By Snooze1 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-06-2009, 07:47 AM
  3. golf tdi S 90 BHP P1556 fault code, please help
    By gti203 in forum Golf MK4 - 1999 - 2004
    Last Post: 19-05-2008, 10:48 PM
  4. VW GOLF TDI S 90 BHP power loss P1556 fault code, please help
    By gti203 in forum New Member Introductions
    Last Post: 19-05-2008, 10:47 PM
  5. 24 MILLIONTH GOLF ROLLS OFF LINE - EXPANDED UK GOLF RANGE
    Last Post: 19-11-2005, 05:57 PM
