Thread: B5 Passat Electrical issue
Results 1 to 9 of 9
  1. Smile B5 Passat Electrical issue
    Mar 2010
    Shrewsbury
    Hi everyone,
    This is my first post (so please be gentle) We have just purchased our (sold as seen) R reg Passat TDi 110 with 145K miles, and we are having a few issues.
    I purchaced the car at a very good price for my wife to use for work and run the family around and we are very happy with it until we found that on the odd occasion we would unlock the car and drive down the road and find that we have no lights or indicators, wipers - nothing only hazard lights. If we turn the car off and lock it and unlock it from the key fob it works fine.
    I am not sure if this is an electrical short or the imobiliser not working correctly. has anyone else had this issue?
    Second thing is we have a rattle from the breaks when we apply the breaks. I have removed the pads and found a raised shoulder on the bottom of the pad where it hangs over the center of the break disc by about 10mm. It looks as if we have the wrong disc's on the car. When i went to my local motor factors they assure me that i have the correct break pads. Has any one else had this issue?
    Cheers for your time
    Gaz n Shaz aka Gubiee
  2. Re: B5 Passat Electrical issue
    Feb 2010
    uk
    From what i have read on this forum it sounds like your comfort control module is playing up. Its probably down to water ingress due to blocked drain holes under the battery.
    easy enough to sort if you're fairly competent with the spanners.
    is your carpet wet on the passenger side? pull it up and check under it.
    Your second fault could just be down to worn discs but also wrong discs, wrong pads, maybe even wrong callipers. If it was mine i would be taking measurements of everything and checking with a manual to see if its got the wrong stuff fitted.
    Good luck mate.
  3. Re: B5 Passat Electrical issue
    im guessing your passat is a mark 4. so im basing these figures on that
    vented discs = 256mmx20mm 4 studded wheel .
    solid disc = 256mmx13mm
    pads for the car are all the same shape , only difference being the pads for solid discs had a few extra mm of brake lining . The 97to 2005 passat however had 2 kinds of front pads.
    caliper was made for the car by Girling , it should have the number 54 stamped on it somewhere along its face.
  4. Re: B5 Passat Electrical issue
    Norfolk
    Quote Originally Posted by gubee View Post
    Hi everyone,
    Your electrical problems are probably due to the terminal 30 voltage relay on the relay plate under the drivers dash. Get another one from VW and swap it. Unless you know what you are doing, it's best to just swap it rather than test for a fault. It could also be a wiring fault in the same area. If it is the relay it is a simple fix.
  5. Re: B5 Passat Electrical issue
    Mar 2010
    Shrewsbury
    Quote Originally Posted by passat 130 tdi View Post
    Hi there
    First, thanks for the great response and making us feel welcome. We have located the issue and we think we have got the wrong disc's. We have got an R-reg mark 5 with the 5 stud wheels. so we have a choice of 3 different diameter sizes of vented discs.
    We now need to find out the minimum distance between the caliper and the outter edge of the disc or the correct diameter of the disc as it looks as if our discs are too small.
    again cheers for the response,
    Gaz
  6. Re: B5 Passat Electrical issue
    Mar 2010
    Shrewsbury
    Quote Originally Posted by martin1810 View Post
    Think that this will need to be a sunday afternoon job with several cups of tea!
    Thanks for the response
  7. Re: B5 Passat Electrical issue
    Mar 2010
    Shrewsbury
    Quote Originally Posted by Rexer View Post
    Good luck mate.
    I guessing that i will need to remove the battery and tray for this one then? Last time i checked the passenger footwell was dry.
    Cheers for the response.
  8. Re: B5 Passat Electrical issue
    Jul 2008
    Not nearly as bad as it sounds - this thread will help:
    https://www.vwaudiforum.co.uk/forum/s...ad.php?t=91422
    Here's a dodgy guide: https://www.vwaudiforum.co.uk/forum/s...ad.php?t=92813
  9. Re: B5 Passat Electrical issue
    VERY RARE - ONLY EARLY MODELS vin - 3BX124107 ATE CALIPERS 282X25 UPTO 1997
    ATE CALIPERS VIN - 3BX124108 288MM X 25MM 1997 ONWARDS
    LUCAS ( GIRLING ) CALIPERS 280MM X 22MM UPTO YEAR 2000.
  1. Some advice please needed on wheel offsets - ET37 vs ET35
    By Staz in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-12-2007, 05:48 PM
  2. Replies: 0
    Last Post: 10-11-2007, 08:05 PM
  3. 1999 Passat Boot Issue
    By EngineerVW in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-09-2007, 06:10 PM
  4. Replies: 3
    Last Post: 01-03-2007, 08:47 PM
