Thread: A4 2.5 TDI wont Start - Fuel Injector Pump?
  1. A4 2.5 TDI wont Start - Fuel Injector Pump?
    Mar 2008
    My Audi A4 2.5 tdi 1998 MY broke down last week (was low on fuel)
    The RAC had the engine run on easy start (so cam belt OK)
    Topped up diesel
    And there was fuel coming out of the injectors, but it would not start on Diesel only?
    The Garage said the Fuel Injector Pump is showing as a fault but they dont have the full Audi diagnostics?
    They mention and ECU being part of the pump and that it wil be an expensive job.
    Any advise on what to do next?
  2. Re: A4 2.5 TDI wont Start - Fuel Injector Pump?
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Its an Electronic Pump yes, but the ECU is seperate.A fault code read is your best bet before chucking money at it.
    Alan.
    VW T6 150 DSG Camper £££
  3. Re: A4 2.5 TDI wont Start - Fuel Injector Pump?
    Mar 2008
    Thanks Alan,
    I have been told its the EDC part of the pump.
    Found www.dieselpumprepairs.com who claim to be able to repair the EDC? has anyone used there services?
    Does anyone know of the cheapest option of getting a second hand pump?
    Scrap yard?
    Part No 059130106DX??
  4. Re: A4 2.5 TDI wont Start - Fuel Injector Pump?
    Nov 2008
    20 Post(s)
    Hi,how sure is the garage of the pump being at fault? Other issues can put a Pump Fault on,but because its the effect of a fault,not the cause of it.
    Alan.
  5. Re: A4 2.5 TDI wont Start - Fuel Injector Pump?
    Jul 2008
    Wales
    Mine went last year, 2.5tdi AFB. the AA get it running with spray, but otherwise wont run. I read the codes and it showd (01318 – control module for injection pump (J399) 37-00 faulty) which means that the circket boart that is bilt into the pump had gone. this place did mine http://www.pbasher.com/ you can ether send yours in, they fix it and send it back, about 4 days, or they can send out a recon pump next day but costs a bit more. But you should read the codes first to be poitive
    Good luck
    Lyn.
  6. Re: A4 2.5 TDI wont Start - Fuel Injector Pump?
    Mar 2008
    Hi Lyn,
    How did you get the pump removed from the vehicle?
    I'm hereing its a hard job?
  1. 2.5 TDI V6 Fails to Start
    By snapdragon in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-10-2013, 08:31 PM
  2. Please Help A4 2.5 TDI Convertible
    By JonLees in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-02-2010, 01:44 PM
  3. 1999 V6 2.5 TDI A4 SE - Will not start HELP!
    By triman in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 31-01-2007, 01:31 PM
  4. ADVANCED NEW FOUR-CYLINDER PIEZO TDI ENGINE
    Last Post: 17-05-2006, 08:14 PM
  5. New Audi A4 raises stakes in the compact executive class
    Last Post: 13-09-2004, 07:51 PM
