Thread: Wheel Wobble with small turns of steering wheel
  1. Wheel Wobble with small turns of steering wheel
    Jul 2008
    Hi, I have just bought 01 tdi 130 passat and whenever I move the steering wheel slowly small turns left to right it seems almost to bite back or jerk...
    Right wheel has wear in middle tyre??
    Car drives and brakes in straight line,theres no bangs or knocking,no nervousness or shaking like wheel balancing needed dont eg. 60mph.
    Any help plz???
    P.S Jacked car up shook **** outa wheel and no play...
    Thanx!
  2. Re: Wheel Wobble with small turns of steering wheel
    Jul 2008
    Check the power steering fluid.
    Check the track rod ends.
    BUT sounds like you need new front tyres.
  3. Re: Wheel Wobble with small turns of steering wheel
    Jul 2008
    Cheers man!
    Had it up dont know how many times cant see anyplay!
    Was worried incase suspension as heard on passat they aren't gr8!
    BUT tyres on front her R well done!
    Cracks in side wall etc
    So new set rubber it is
  4. Re: Wheel Wobble with small turns of steering wheel
    Have the top of the strut load bearings checked. If one of these seize up the steering goes in small jumps. Regards Peter
  5. Re: Wheel Wobble with small turns of steering wheel
    Jul 2008
    badtimes!
    Went out4 another look there and drivers side 'drive shaft' is knocking and passerner side tight
  6. Re: Wheel Wobble with small turns of steering wheel
    Jul 2008
    Just back in there and bloody drive shafts are both tight now.
    drivers shaft has no play init 2day! waaaaaa
  7. Re: Wheel Wobble with small turns of steering wheel
    You're not making any sence. You either have a worn notchy drive shaft or you do not. Are you suggesting that the jumpy steering only happens when moving. Regards Peter
  1. Heater Control Cable (air Distribution)
    By kwic50 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 29-09-2023, 03:11 PM
  2. Retro-fit leather steering wheel - how much?
    By Typ 5K in forum Golf MK6 - 2009 - 2013
    Last Post: 01-09-2009, 12:10 PM
  3. Question Golf Mk4 GT TDI Rear Wheel Bearing
    By tommi in forum Golf MK4 - 1999 - 2004
    Last Post: 25-05-2009, 08:21 PM
  4. steering wheel judder between 60 and 70 when braking.
    By Robin Vitiello in forum Alhambra
    Last Post: 19-06-2008, 07:34 PM
  5. Parrot CK3000 intstall with Multican OEM steering wheel control
    By Mikey_p in forum Audi A3 - Archive Topics
    Last Post: 03-06-2007, 05:35 PM
