Thread: Balancer Shaft Problems ?
  1. Balancer Shaft Problems ?
    Jan 2009
    I hope my post is not too basic for this forum..
    I have been looking at other forums (sorry) and have come across issues regarding Balancer Shaft Problems, on B5 models in the US. It is a common occurance for the BHW 2.0 TDI motor I have been told.
    I have a 2003 1.9TDI PD - 130bhp passat.
    I want to know if this is a common problem in this model or just the 2.0 models. I have done some research and not found a complete answer.
    Waseem
  2. Re: Balancer Shaft Problems ?
    Feb 2010
    Ashford, Kent
    I'll go one step simpler than that, what's a balancer shaft??
  3. Re: Balancer Shaft Problems ?
    Norfolk
    I guess you mean the oil pump/balancer shaft assembly. That is only used in the 2.0 engine. Never in the 1.9 so you don't have to worry.
  4. Re: Balancer Shaft Problems ?
    1840 Post(s)
    Jamiem http://en.wikipedia.org/wiki/Balance_shaft
    Neovw, not an issue on your engine.
  5. Re: Balancer Shaft Problems ?
    Sep 2012
    Dublin, Ireland
    Hi. The 1.9 PD (Pumpe Deuse) engine doesnt have the oil pump and balance shaft problems that are associated with the 2.0 TDI engine. If its a high miler automatic gearbox though, its worth changing the transmission oil once you get past 120k. Not an easy job but necessary despite what your VW dealer says.
  1. 5 speed gearbox selector problems
    By firelizard in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-05-2010, 02:51 AM
  2. 2.0 TDI Oil Pump Balance Shaft Problems
    By Jack Ford in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 24-01-2010, 07:01 PM
  3. 2.0 TDI Oil Pump Balance Shaft Problems
    By Jack Ford in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 24-01-2010, 11:39 AM
  4. Engine curring out on the motorway & other problems - please help!
    By oshy1981 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-04-2009, 06:38 PM
  5. "How To" The FAQ & How To Thread
    By Ben in forum General
