Thread: Remote Central Locking Addition to an 02 Polo
Page 2 of 10 FirstFirst 1234 ... LastLast
Results 11 to 20 of 100
  1. Re: Remote Central Locking Addition to an 02 Polo
    Jan 2010
    Liverpool
    If you dont mind you could have a little look at this, this is all the information i have
    https://www.rclick.co.uk/information.php?info_id=13
    you may need to register, only needs an email, sorry
    Thanks again
  2. Re: Remote Central Locking Addition to an 02 Polo
    May 2007
    17 Post(s)
    I've checked and the resistor that you need is 180 Ohm, 0.25 Watt.
    You wire your interface box to output negative pulses.
    The central locking control wire on the Polo is on the white 6 pole connector on the drivers A pillar, where the door wiring connects.
    The wire your looking for is blue/white and is on pin 5 of the connector. I've made a note that the wire may be coloured white on some cars.
    Connect the LOCK wire of your interface directly to the blue/white wire on the vehicle loom.
    Connect the UNLOCK wire to the 180 Ohm resistor.
    Now connect the other end of the resistor to the Lock wire of the interface box.
    If you need to connect your unit to the indicators they can be found on the black 16 pole connector on the power supply ECU under the dash at the pedals. I think that is the connector to the rear right of the ECU. When I say rear, I mean towards the dash, not the bulkhead. The wires are black/green (pin 14) and black/white (pin 16).
    I take the positive supply from the light switch. It's a heavy red wire. To remove the switch, push the knob in and turn it to the side light position. Now pull it towards you. The earth wire just screws on to the body. I usually use one of the dash fusebox securing screws.
    I hope that helps.
    Jim
    3 1 0
  3. Re: Remote Central Locking Addition to an 02 Polo
    May 2007
    17 Post(s)
    Quote Originally Posted by Flash2 View Post
    Should have said, you should be able to get the resistor from your local Maplin store. Costs about 3p. (http://www.maplin.co.uk/)
    Jim.
  4. Re: Remote Central Locking Addition to an 02 Polo
    Jan 2010
    Liverpool
    Thanks, so did you mount the unit in the drivers door? sounds like more of a job than i thought bit lets give it a go hey
  5. Re: Remote Central Locking Addition to an 02 Polo
    May 2007
    17 Post(s)
    No, you mount the contol unit under the dash. It depends on the size and shape of the box. I cable tied mine onto the relay plate, behind the little trim that pulls off to the right of the steering cowling.
    It's not really that big a job. When you think about it, you are only connecting 6 wires to the vehicle and I've told you where you've to connect them. The job is half done already.
    B+, IGN+, EARTH, 2X INDICATORS, and a wire to the central locking. 6 wires, that's all you need to make it work.
    Good luck!
    Jim.
  6. Re: Remote Central Locking Addition to an 02 Polo
    Bristol
    Good luck!
    Jim.
    Where are the indicator connections Jim? I've nit managed to get them connected yet.
  7. Re: Remote Central Locking Addition to an 02 Polo
    #17
    May 2007
    17 Post(s)
    Quote Originally Posted by vc-10 View Post
    Hi Vickers. (VC-10?)
    See the attached photo.
    Jim.
  8. Re: Remote Central Locking Addition to an 02 Polo
    #18
    Bristol
    Fantastic! So I just connect the indicator outputs on the central locking box to these?
  9. Re: Remote Central Locking Addition to an 02 Polo
    #19
    May 2007
    17 Post(s)
    Yes.
  10. Re: Remote Central Locking Addition to an 02 Polo
    #20
    Bristol
    Great! Thank you very much for your help.
  1. B5 A4 Central Locking FAQ
    By ini in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-09-2015, 11:46 AM
  2. Please Help Octavia- Central locking keeps locking.
    By Mawb in forum Octavia
    Last Post: 27-09-2013, 02:53 PM
  3. Remote? Central Locking Unit
    By ImCammers in forum Golf MK4 - 1999 - 2004
    Last Post: 13-09-2009, 07:08 PM
  4. Problems connecting Remote Central Locking ...2004 Polo E
    By andy4976 in forum Polo - Derby - Lupo - Fox
    Last Post: 29-06-2009, 10:24 AM
  5. Help installing remote for central locking on R reg polo 1.6l
    By ukeminem88 in forum Polo - Derby - Lupo - Fox
    Last Post: 22-07-2007, 02:29 AM
