Thread: A6 C6 VCDS Changes - Post & Pre Facelift
Page 2 of 17 FirstFirst 123412 ... LastLast
Results 11 to 20 of 168
  1. Re: VCDS changes
    46 Post(s)
    Original post now updated with Pre-facelift changes 20/7.
    Also stickied for more coverage.
    If any have been missed please reply and these can be added.
  2. Re: VCDS changes
    Sep 2008
    mostly in the garage
    I don't see adding 'Lap timer' anywhere so far so you can add that.
    address 17 instruments
    use long code helper
    change byte 1 bit 3 to make lap timer active.
    It then becomes an option in the DIS screen, the oil temperature display is probably the most useful but there is a timer and a gimmicky boost gauge as well.
    2 0 0
  3. #13
    46 Post(s)
    Thanks will add soon
  4. Re: A6 C6 VCDS Changes - Must See!
    Feb 2009
    Has anyone managed to enable ambient lighting on the faclift 2009+ models?
    I've tried but have no ability to adjust the Byte / Bit in the long code helper, nothing is shown.
    I got this to work easily on my 06 Plate A6, but no luck on my 10 plate.
  5. Re: A6 C6 VCDS Changes - Must See!
    May 2009
    Ramsey, New Jersey, USA
    69 Post(s)
    Quote Originally Posted by Blackavant View Post
    My last C6 facelift (2009 Le Mans) had the Ambient Lighting pack fitted as standard. I still have the scans from the car. Which module do you need the coding for? You could try copying mine to see if it works?
    Here is the last scan I took in March 2012:
    VCDS Version: Release 11.11.2 (x64)
    Data version: 20120126
    Thursday,01,March,2012,09:55:17:07948
    Chassis Type: 4F0
    Scan: 01 03 05 08 09 15 16 17 19 42 46 4F 52 53 55 56 5F 62 72 76
    VIN: WAUZZZ4F09N055366 Mileage: 90000km/55923miles
    01-Engine -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    5F-Information Electr. -- Status: OK 0000
    76-Park Assist -- Status: OK 0000
    Address 01: Engine (J623-CAHA) Labels: 03L-906-022-CAG.clb
    Part No SW: 03L 906 022 FG HW: 03L 906 022 FG
    Component: R4 2,0L EDC H01 4397
    Revision: 11H01--- Serial number:
    Coding: 0105002C18072118
    Shop #: WSC 02325 785 00200
    ASAM Dataset: EV_ECM20TDI03L906022FG A01006
    ROD: EV_ECM20TDI03L906022FG.rod
    VCID: 6FE6D970B6862DB
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 4F0-910-517.lbl
    Part No SW: 4F0 910 517 AK HW: 4F0 614 517 AT
    Component: ESP8 front H03 0060
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0020859
    VCID: 6DDAC378748ADFB
    Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
    Part No SW: 4F0 910 852 B HW: 4F0 905 852 D
    Component: FBSAUDIC6 ELV H05 0100
    Revision: 00H05000 Serial number: 10602601299048
    Coding: 0000017
    Shop #: WSC 02324 785 00200
    VCID: 254AFB58ECFA27B
    Part No: 4F0 910 132 D
    Component: FBSAUDIC6 EZS H03 0020
    Part No: 4F0 910 220 D
    Component: FBSAUDIC6 IDG H01 0040
    Address 08: Auto HVAC Labels: 4F0-910-043.lbl
    Part No SW: 4F0 910 043 B HW: 4F2 820 043 AA
    Component: KLIMABETAETIGUNGH30 0080
    Revision: 00000074 Serial number: 00000030430038
    Coding: 0001044
    VCID: 1D3AD3B8C4AAEFB
    Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
    Part No SW: 4F0 910 279 N HW: 4F0 907 279
    Component: ILM Fahrer H22 0320
    Revision: 00000000 Serial number: 4F0907279
    Coding: 0013121
    Shop #: WSC 02256 785 00200
    VCID: 346C161C57204E3
    Subsystem 1 - Part No: 4F2 910 113 C Labels: 1KX-955-119.CLB
    Component: Wischer AudiC6 H10 0040
    Coding: 00056595
    Shop #: WSC 02256
    Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
    Component: REGENLICHTSENSORH04 0003
    Coding: 00146221
    Shop #: WSC 02256
    Address 15: Airbags (J234) Labels: 4F0-910-655-10.clb
    Part No SW: 4F0 910 655 L HW: 4F0 959 655 E
    Component: Airbag AU1042 H06 0090
    Revision: -------- Serial number: 003CH004D55G
    Coding: 30314236303630303033554A305234463053
    ASAM Dataset: EV_Airba10AURB4 001001
    ROD: EV_Airba10AURB4.rod
    VCID: 30641A0C6B38723
    Crash sensor for side airbag; driver side:
    Serial number: 3574SRB400008C651AFH
    Crash sensor for side airbag; passenger side:
    Serial number: 3584SRB400008C5C819G
    Crash sensor for side airbag; rear driver side:
    Serial number: 35152RB402T85LSIV3L9
    Crash sensor for side airbag; rear passenger side:
    Serial number: 35252RB402B85LSJ3BA5
    Crash sensor for front airbag; driver side:
    Serial number: 3554NRB400004B2A387+
    Crash sensor for front airbag; passenger side:
    Serial number: 3564NRB400004B32BAFA
    Address 16: Steering wheel Labels: 4F0-910-549.lbl
    Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
    Component: J0527 0530
    Revision: 00H05000 Serial number: 90055090630424
    Coding: 0102041
    VCID: 2756F15096F635B
    Part No: XXXXXXXXXXX
    Component: E0221 H02 0030
    Address 17: Instruments (J285) Labels: 4F0-920-xxx-17.clb
    Part No SW: 4F0 920 983 B HW: 4F0 920 983 B
    Component: KOMBIINSTR. H06 0135
    Revision: 00100000 Serial number: AE944MT29
    Coding: 2F74080502002600010400
    Shop #: WSC 02391 823 56573
    VCID: 2B5E0D604A1E11B
    Address 19: CAN Gateway (J533) Labels: 4F0-907-468.clb
    Part No SW: 4F0 907 468 K HW: 4F0 907 468 F
    Component: GW-BEM 4CAN-M H06 0025
    Revision: 4LA80024 Serial number: 2400L09330837F
    Coding: 000303
    VCID: 377621108656A5B
    Subsystem 1 - Part No SW: 8K0 915 181 C HW: 8K0 915 181 C
    Component: J367-BDM H07 0107
    Address 42: Door Elect, Driver (J386) Labels: 4F0-959-793.clb
    Part No SW: 4F0 959 793 R HW: 8K0 959 793 D
    Component: TSG FA H11 0250
    Revision: Serial number: 0000100888916
    Coding: 011F06204041410001
    VCID: 46885CD4F1BCCC3
    Address 46: Central Conv. Labels: 4F0-910-289.lbl
    Part No SW: 4F0 910 289 N HW: 4F0 907 289 N
    Component: Komfortgeraet H28 0240
    Revision: 02400028 Serial number: 01177736730000
    Coding: 0139771
    VCID: 356A2B185C5A57B
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Part No: 4F0 910 177
    Component: Innenraumueberw.H01 0020
    Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
    Part No SW: 4F0 910 280 HW: 4F0 907 280 A
    Component: ILM Beifahrer H13 0100
    Revision: Serial number: 00000000623181
    Coding: 0001104
    VCID: DEB814B4092C343
    Address 52: Door Elect, Pass. (J387) Labels: 4F0-959-792.clb
    Part No SW: 4F0 959 792 R HW: 8K0 959 792 D
    Component: TSG BF H11 0250
    Revision: Serial number: 0000100894992
    VCID: 458A5BD8CCBAC7B
    Address 53: Parking Brake Labels: 4F0-910-801.clb
    Part No SW: 4F0 910 801 D HW: 4F0 907 801 B
    Component: EPB CEFC0090 H05 0090
    Revision: --H05---
    Coding: 0000111
    Shop #: WSC 02145 785 00200
    VCID: 2142EF48F8D2CBB
    Address 55: Xenon Range Labels: 8P0-907-357.lbl
    Part No: 8P0 907 357 H
    Component: Dynamische LWR H02 0010
    Revision: 00000001 Serial number:
    Coding: 0000003
    VCID: 3F8649306E669DB
    Address 56: Radio (R) Labels: Redir Fail!
    Part No SW: 4F0 035 056 J HW: 4F0 035 056
    Component: Radio U STD H45 0052
    Revision: AB001007 Serial number: 342D.097595266
    Coding: 010003020100000000
    Shop #: WSC 00778 210 81005
    VCID: 2756F15056F635B
    Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
    Part No SW: 4E0 035 666 D HW: 4E0 035 666
    Component: H-BN-EU H64 0143
    Revision: -------- Serial number: 345BY097545942
    Coding: 010101000102C3ED01000315EF6300030001
    Shop #: WSC 00778 210 97003
    Subsystem 1 - Part No: 8R0 060 884 R
    Component: EUR 2010 1107
    Subsystem 2 - Part No SW: 4F0 919 604 HW: 4F0 919 604
    Component: DU7 High H43 0306
    Subsystem 3 - Part No SW: 4F0 910 609 E HW: 4F2 919 611 M
    Component: Bedienteil MM H01 0060
    Address 62: Door, Rear Left (J388) Labels: 4F0-959-795.clb
    Part No SW: 4F0 959 795 M HW: 8K0 959 795 B
    Component: TSG HL H10 0251
    Revision: Serial number: 0000100898708
    Coding: 010E04204041220001
    VCID: 438E45C0C28EF9B
    Address 72: Door, Rear Right (J389) Labels: 4F0-959-795.clb
    Component: TSG HR H10 0251
    Revision: Serial number: 0000100906585
    Address 76: Park Assist Labels: 4Fx-910-283.lbl
    Part No SW: 4L0 910 283 C HW: 4L0 919 283 C
    Component: Parkhilfe 8-Kan H02 0500
    Revision: 00H02000 Serial number: 12630908904181
    Coding: 0200006
    VCID: 2A50086485E4083
    Cheers!
    MF.
    Now: E 53 AMG 4MATIC
    / Q5 2.0TFSi Prestige
  6. Re: VCDS changes
    Sep 2011
    Lurking over a keyboard ...
    Quote Originally Posted by c4a5er View Post
    AFAIK only work on face lift cars as tried this when got my VCDS in Jan on mine and did not work
  7. Re: VCDS changes
    #17
    May 2009
    69 Post(s)
    Quote Originally Posted by gupsterg View Post
    Yep - only applicable to facelift cars with the new-design cluster.
    MF.
  8. Re: VCDS changes
    #18
    Oct 2006
    The mods I have done that aren't mentioned already here (pre facelift):
    1. Changed the MMI boot/standby screen from the boring standard one to the RS6 one.
    Control Head - Coding - Change 3rd digit (..X....) from 0 to 3. 0 is A6, 1 is S6 and 3 is RS6. This also makes the car feel much faster!
    2. Disabled seatbelt warning. In my circumstances (no kids in car) I like to have full control and in the rare event it used to warn me, it was due to pressure from something on the passenger seat that wasn't actually a passenger. I tend to know if I am wearing my seatbelt or not!
    Instrument Cluster - Coding - 6th digit (.....X.)
    0 = No Seatbelt Warning
    1 = Seatbelt Warning (EU-NCAP)
    2 = Seatbelt Warning (NAR Old)
    3 = Seatbelt Warning (NAR New)
    4 = Seatbelt Warning (EU-NCAP incl. Passenger)
    5 = Seatbelt warning (NAR Old incl. Passenger)
    6 = Seatbelt Warning (NAR New incl. Passenger)
  9. A6 C6 VCDS Changes - Post & Pre Facelift
    #19
    46 Post(s)
    Will add those to the original post .. Ta!
    Edit - Now added.
  10. Re: A6 C6 VCDS Changes - Post & Pre Facelift
    #20
    Sep 2011
    Hi peeps ...
    I was going to add voice control at some point to my car...
    As a test I enabled voice control in the bluetooth module...
    Ref link:- Audi A6 (4F) Telephone Preparation - Ross-Tech Wiki
    [77] - Telephone
    00x0x?0: Voice Control Language
    • 2 = English (United Kingdom)
    On Link:- Ross-Tech 4F wiki they show it will work for BT modules with labels 4E0-910-336 & 4F1-910-336 ... but not 4E0-910-333...
  1. Question Facelift interior into pre-facelift car 5-door
    By westiej in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 08-11-2014, 11:30 AM
  2. A6 C6 pre to post facelift rear diffuser swap
    By 692DPG in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 05-12-2013, 06:22 PM
  3. Thinking of a 2.0 tdi avant.. Pre Facelift or Facelift?? Difference of 4 Grand.
    By mrosd in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 13-07-2012, 07:49 AM
  4. What mods available foe pre-facelift A6 C6 with VCDS?
    By Brycie in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 18-05-2012, 09:57 PM
  5. Please Help Avant Facelift to Pre-Facelift Tailgate Swap
    By mixmaster_mike in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-08-2011, 11:55 AM
