Thread: POLO Abs Light
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
  1. Question POLO Abs Light
    Dec 2005
    Hi Everyone,
    please can someon help. . .?
    My wife has a 51 Reg Polo 1.0L that is now displaying
    the ABS light on the dashboard.
    We have owned the car from new, and it has just 15k miles on the clock.
    One careful lady owner, supermarket and school runs only !
    The problem is intermittent, sometimes the light is comes on and stays on, other times it comes on and goes off.
    I'm suspecting a faulty ABS sensor ???
    Am i right ?
    If so, has anyone got any ideas how much it may cost to replace/fix at my local VW dealer ?
    As always, your thoughts and help would be much appreciated,
    Many Thanks
    Adam
    Feb 2004
    Yorkshire
    46 Post(s)
    Hi Adam
    It does sound to me like a fault with the ABS sensor. What I would suggest is visiting a local garage or VW specialist (cheaper than dealer ) and let them plug it into the diagnostic machine, this will tell them which sensor, or any other component for that matter.
    If it is a sensor, try your local GSF or Euro Car Parts, may be cheaper
    Stuart
    Stuart l VWAudi Forum
    VW Audi Forum - Founder
    Member of BMW Car Club GB
    Ways to support the website
  3. Question Polo ABS Light - DIY fix ?
    Dec 2005
    Thanks Stuart,
    we don't have a local VW Non-Dealer specialist. . .
    My local garage which usually MOT's and oil changes the car, ran a diagnostic on my VW Passat diagnosing a faulty ECU.
    They suggested it would cost up to £1000 to fix.
    VW sorted the problem for £88, and diagnosed a faulty switch
    on the coolant system.
    Thus, I'm reluctant to take it back to a non-VW outfit.
    Any ideas how easy the job is to do myself ?
    If so, any ideas how many ABS sensors the car has, and
    how I can tell which one has failed ?
    Sorry about all the questions, you must fell like your on VW Mastermind !
    Your help is appreciated,
    Cheers,
    Adam
    Feb 2004
    Yorkshire
    46 Post(s)
    Mmmm... Think they tried to "rip you off"
    Most cars have 4 ABS sensors, one on each wheel, any of which will bring up an ABS fault. They are fitted in each wheel hub, usually about 20mm in diameter, held by a bolt with a single cable out.
    The problem is,if you do not get it plugged into a diagnostic machine you will not know which is at fault
    Stuart
  5. Thumbs up ABS Sensor - Let's see what we can see !
    Dec 2005
    Many Thanks Stuart,
    I'll take the wheels off first. . and see if I can see any obvious damage to any of the ABS sensors.
    Failing that I'm off to VW for a diagnostic.
    I'll keep you posted,
    Regards,
    Adam
  6. Re: POLO Abs Light
    Jun 2007
    The last time I had a fault with my ABS Sensors my VW mechanic charged me £175.....if that helps....
  7. Re: POLO Abs Light
    Mar 2010
    London
    Is this possible to do yourself once you find out which sensor is faulty?
    Got ABS light on and was thinking of getting one of those vag-com cables and the freebie shareware software to diagnose which one is at fault...
  8. Re: POLO Abs Light
    Jun 2007
    My ABS light is now permanantly on at last diagnosis it was the ABS sensor, even from GSF my mechanic charged me £175 each, loathe to pay this...
  9. Re: POLO Abs Light
    Mar 2010
    London
    So, has anybody done it yourself? Think the sensor is only ~£20 from gsf.....just wondered whether it is soemthing you can do yourself?
  10. Re: POLO Abs Light
    Aug 2009
    London
    we did this outself
  1. Polo 1.4 16V - EPC light, oil and service light issues
    By Trinster in forum Polo - Derby - Lupo - Fox
    Last Post: 19-08-2011, 08:57 PM
  2. polo gti abs warning light
    By gtifan in forum Polo - Derby - Lupo - Fox
    Last Post: 18-06-2009, 04:47 PM
  3. Serive light on 02 Polo
    By gingersteve in forum Polo - Derby - Lupo - Fox
    Last Post: 27-03-2007, 07:50 PM
  4. Polo ABS warning light
    By jeffbm in forum Polo - Derby - Lupo - Fox
    Last Post: 06-03-2007, 12:39 AM
  5. VW Polo ABS Light not again!
    By alexed in forum Chat - Completely Off Topic
    Last Post: 14-07-2006, 03:42 PM
