Thread: 51 plate Bora - New pads, how to avoid "Check Brake Pads"?
  1. 51 plate Bora - New pads, how to avoid "Check Brake Pads"?
    Oct 2009
    liverpool
    Hi Fella's
    Quick one for you all....
    Mate at work with a 51plate Bora 2.0 had a service and new pads all round from a mobile mech (would have done it for hime myself if I hadnt recently moveed so far away)..... basically the mechanic used good, but non original pads
    Basically, wneh he switches the car on, he now gets a "check brale pads" warning on the dash, and the light stays on.
    Is there a way of cheating the system to avoid this until they need replacing again? Can the wire that usually plugs into the pads be bridged somewhere?
    Car is fine, and stops well... I think he just finds it annoying
    Ta in advance
    G
  2. Re: 51 plate Bora - New pads, how to avoid "Check Brake Pads"?
    Oct 2009
    liverpool
    really?
    nobody knows how to get rid of the warning having fitted pads without a fitting for the wear sensor?
    G
  3. Re: 51 plate Bora - New pads, how to avoid "Check Brake Pads"?
    Newcastle
    Yes, all you need to do is connct the two wires together where the plug is for the pads
  4. Re: 51 plate Bora - New pads, how to avoid "Check Brake Pads"?
    Oct 2009
    liverpool
    do you mean the wire for the offside caliper and the nearside caliper?
    Ta
    G
  5. Re: 51 plate Bora - New pads, how to avoid "Check Brake Pads"?
    Newcastle
    The wear wire is only on one side
  6. Re: 51 plate Bora - New pads, how to avoid "Check Brake Pads"?
    Sep 2007
    Plymouth
    You just need to create a jumper across the socket. Bend a thin nail, paperclip or something like that into a u shape and then insert making sure contact is made on both points of the socket.
    2003 A6 1.9TDI PD Avant SE 359,000 miles
    Cannondale Road Bike
    Yeti ASR SL Mountain Bike
    9ft 4inch Surfboard (two of)
  1. Please Help Brake pads on a passat v5 (52 plate)
    By nprescot in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-04-2009, 02:03 PM
  2. Green Stuff Brake Pads
    By M53494 in forum Golf MK4 - 1999 - 2004
    Last Post: 10-04-2008, 01:18 PM
  3. Changing Brake Pads
    By super_dudes in forum Polo - Derby - Lupo - Fox
    Last Post: 14-02-2008, 07:18 PM
  4. VW Bora brake pads and discs
    By Craig Allen in forum Bora - 1998 - 2005
    Last Post: 13-08-2007, 11:45 AM
  5. A4 Quattro Servicing Tasks
    By MrBeardy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-08-2007, 04:57 PM
