Thread: ESP Light on & Shuddering?
Results 1 to 9 of 9
  1. ESP Light on & Shuddering?
    Sep 2008
    Hi all, I was driving along today, my ESP light came on and the car started shuddering under acceleration. The ESP light has stayed on and everytime I try to accelerate it really shudders quite bad. Also now sat at idle its running rough and sounds like some cylinders are not firing. Its a 1.9TDI model.. Any ideas?!?!
  2. Re: ESP Light on & Shuddering?
    Aug 2008
    Hereford
    Get it vagcom'd, could be a number of things, esp light could be due to abs sensors, module, pump
  3. Re: ESP Light on & Shuddering?
    Sep 2007
    Plymouth
    In this case it will most likely be the in head injector wiring loom. This sits under the rocker cover and is a common failure and gives the symptoms you have.
    The replacement loom from VAG is usually about £44 and it takes one hour on average to replace. There are plenty of tips of how to do these throughout the forum, please do a search for furter information.
    If this is in fact the issue, it's not a biggy to sort.
    2003 A6 1.9TDI PD Avant SE 359,000 miles
    Cannondale Road Bike
    Yeti ASR SL Mountain Bike
    9ft 4inch Surfboard (two of)
  4. Re: ESP Light on & Shuddering?
    May 2010
    Nexton
    I have the same problem: ESP light on and engine running badly. If you are still around gashair, how did you solve it?
  5. Re: ESP Light on & Shuddering?
    Sep 2008
    Hi ya,
    Well after waiting for replies and reading through them it, it cured itself, so actually didn't do anything in the end!! The wiring loom seemed reasonable, now that the drier warmer weather is here, it could have dried out and now works fine!
  6. Re: ESP Light on & Shuddering?
    Apr 2007
    N.Ireland
    Had the same problem myself a few months ago. Replacing the injector wiring loom fixed it
    Golf GTD 2.0 DSG (ACC | Winter Pack | 18" Vancouvers | RCD510 | Parking Sensors, Rear Camera & Park Assist | Cruise Control | Flat Tyre Indicator | Luxury Pack | Rear Airbags)
  7. Re: ESP Light on & Shuddering?
    May 2010
    Devon England
    a good test to check that loom is have the engine running and wobble the harness plug, if it pick up and runs fine for a minute thats deffo the fault
  8. Re: ESP Light on & Shuddering?
    Oct 2020
    Lithuania
    Hey all,
    My Golf 4 have same issue with ESP and shuddering when accelerating. ESP light on, and stay it while ignition is ON. Yesterday I take Autocom from job and tried found faults, but it was 0 faults ! Today I call guy, that have VAG diagsnotic, and he dont find any fault codes to...
    Allready tried replace YAW sensor and small sensor near YAW sensor, but noething changes.
    Before wiring loom changing I want be sure, that problem is there
  9. Re: ESP Light on & Shuddering?
    Jan 2016
    italy
    Quote Originally Posted by gashair View Post
    Make a diagnostic in ecm
    Sent from my SM-J415F using Tapatalk
  1. Rear fog light / reverse light fault (golf 5)
    By 85turbo in forum VCDS - General Questions
    Last Post: 03-09-2010, 11:30 PM
  2. "How To" change a rear light bulb on an A3
    By djgilson in forum Audi
    Last Post: 16-04-2010, 03:54 PM
  3. How To ABS + ESP + glow plug light flashing
    By Camb-Tech in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-01-2010, 05:56 PM
  4. ESP warning light coming on Passat TDI 130
    By Dacabbie in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-02-2008, 12:55 PM
  5. ESP
    By tony_anon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 26-01-2007, 11:48 PM
