Thread: Strut Top Mount play
  1. Strut Top Mount play
    Jan 2010
    Wareham
    Newbie cab 96 owner....had for a short while now and first MoT due. Checking around with the car up at the front on stands, wheels a danglin'. Thought the slight wheel wobble and stiffer turning to left rather than right may have been suspension strut top mounts....seems I may have been right, but...
    What sort of play is permissible with the wheels danglin' and the struts fully extended? The 6 and 12 wheel movement test moves the whole strut up and down, both sides, with the offside showing less movement. I would say the vertical movement is about 5mm nearside and 3mm offside.
    I have checked Haynes and think I'm reading it funny - do the springs have to come out to replace these bearings? If so it's down to my local garage - very good blokes - to fix. How long should it take and £££s??
    Cheers for now, any help advice greatly apreciated...
    Janice
  2. Re: Strut Top Mount play
    the struts are a doddle to remove on these, the strut is only held by 2 or 3 bolts. I'm not 100% sure if you need spring compressors when changing the top mount or not though, but you can get them from motorists centres for not much cash, cheaper than paying a garage to do the work anyway.
    only other special tool you need is a castle nut socket, to get thew strut out. helps to have a mate to lend a hand too.
  1. Suspension Strut up and Down Play
    By thedktor in forum Polo - Derby - Lupo - Fox
    Last Post: 29-10-2011, 08:49 AM
  2. Attention IO Play in Audi's
    By fubar84 in forum In Car Entertainment
    Last Post: 06-08-2009, 07:50 PM
  3. top strut mount failure?
    By mk1 out2grass in forum Touran - Sharan - Caravelle
    Last Post: 19-07-2009, 04:16 AM
  4. Suspension Knock - top mount?
    By ben1978 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-04-2008, 03:44 PM
  5. polo strut top play
    By bc123456bc in forum Polo - Derby - Lupo - Fox
    Last Post: 11-02-2008, 09:42 PM
