Thread: Loss of turbo early in journeys
  1. Loss of turbo early in journeys
    Jan 2010
    london
    Hi guys
    I have a Bora Tdi 150 thats covered a fair few miles. I have noticed that after sitting in traffic or early into my jouney having the left the car overnight the turbo does not appear to be there i.e. can't here it and doesn't pull as well. later in the after a few mins I can then feel the turbo come in. The car runs smoothley even without turbo and there are no fault codes. Any ideas? sticking veins? MAF?
    MW
  2. Re: Loss of turbo early in journeys
    1840 Post(s)
    You need to get it fault code read carried out. I imagine one of two fault codes will be stored, 17964 or 17965 and from that we can tell you what to do next.
  3. Re: Loss of turbo early in journeys
    Jan 2010
    london
    I have read the codes and its clear.
    MW
  4. Re: Loss of turbo early in journeys
    1840 Post(s)
    If there are no codes (sorry I missed that bit), fit a new genuine VW dealer supplied exchange Air Mass Meter, DO NOT buy one from anywhere else.
  5. Re: Loss of turbo early in journeys
    Jan 2010
    london
    Well I cant knock how long I had to wait for a reply! thanks for your help. Is there any tests I can do as i am having a bit of a car day and won't have the parts to change any thing tmw?
    MW
  6. Re: Loss of turbo early in journeys
    1840 Post(s)
    Well I suggest you don’t try the disconnecting the AMM test unless you have the ability to double check for fault codes first and then delete the open circuit code after. If you do have your own code reader, then the disconnecting test MAY change the way it behaves but I go buy a simple rule, "no codes, no power, new AMM" and when charging out the work to a customer, this is the most economical test you can do as the price of an AMM fitted is not much more than an hours work.
  1. Please Help Turbo failure again-help please!!!!!!!
    By Tyanu888 in forum Golf MK5 - 2004 - 2009
    Last Post: 17-03-2011, 09:18 PM
  2. Stop / Start - Here's a question for you all??????
    By RickT in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 01-02-2011, 10:32 PM
  3. Cleaning the turbo & power loss A4 1.9 tdi AFN engine 1999
    By fantasiagreen in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 11-09-2010, 12:58 AM
  4. Important Power Loss / Turbo loss on VW Passat 1.9TDI
    By mubsy812001 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-06-2010, 03:14 PM
  5. MK3 TDI turbo dying... remap or hybrid turbo?
    By leoninanegg in forum Golf MK3 - 1993 - 1999
    Last Post: 15-06-2007, 08:48 PM
