Thread: Fault Code Meaning's for A4 02 plate
  1. Fault Code Meaning's for A4 02 plate
    Jan 2010
    Newcastle
    HI there,
    Just borrowed my m8's fault code reader as was having a few problems with my fuel gauge. Filled the tank up yesterday and it seems to be working ok now, maybe the sensors were just gettn stuck!
    any way the fault code reader brought up these error codes, appreciate any help in finding there meanings.........
    01375 01/01 ( which seems to have deleted ?? )
    01119 01/02
    00778 02/02
    Thanks in advance Paul
    Audi A4 Quattro 2.5 TDI SE 180bh
  2. Re: Fault Code Meaning's for A4 02 plate
    01375 - Valves for Engine Mounting: Stage 1: Output won't Switch or Short to B+
    01119 - Gear Recognition Signal Possible Symptoms ABS Warning Lamp active
    00778 - Steering Angle Sensor (G85)Possible Causes Steering Angle Sensor (G85) Basic Setting lost
  3. Re: Fault Code Meaning's for A4 02 plate
    Jan 2010
    Newcastle
    Errrm thanxs for speedy reply..
    Are these serious problems, what do they mean ?
    Sorry i'm not very mechanicaly minded.
  4. Re: Fault Code Meaning's for A4 02 plate
    As long as you have no control lights lighting and the vehicle drives okay ,the codes are nothing to worry about.and they have nothing what so ever to do with the fuel gauge
  5. Re: Fault Code Meaning's for A4 02 plate
    Jan 2010
    Newcastle
    Yeah, no lights lighting and she drives like a dream (Sewell touches wood)
    Many Thanks Kenney, piece ov mind
  1. Audi a8 2003 Current gearshift program problem
    By eints77 in forum VCDS - Help Requests
    Last Post: 20-07-2010, 02:58 PM
  2. low engine power from cold
    By saabsalltheway! in forum VCDS - General Questions
    Last Post: 30-11-2009, 10:21 PM
  3. gearbox isolator switch??????
    By a25c in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 10-11-2009, 11:29 PM
  4. glow plug circuit fault code
    By hoffmeister in forum Octavia
    Last Post: 16-10-2009, 01:19 PM
  5. VAG-COM fault code
    By carlthom in forum Golf MK3 - 1993 - 1999
    Last Post: 31-03-2008, 06:19 PM
