Thread: Lousy fuel economy mk3 cab 1.6 AFT
Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 53
  1. Re: Lousy fuel economy mk3 cab 1.6 AFT
    #21
    Mar 2017
    Serbia
    Denso DOX-0118.
    I cant send you PM for some reason.
  2. Re: Lousy fuel economy mk3 cab 1.6 AFT
    #22
    Mar 2017
    Serbia
    Lambda part number is Denso DOX-0118. I cant send PMs for some reason...
  3. Re: Lousy fuel economy mk3 cab 1.6 AFT
    #23
    1837 Post(s)
    I will PM you.
  4. Re: Lousy fuel economy mk3 cab 1.6 AFT
    #24
    1837 Post(s)
    The VW number for the sensor is 021 906 265 AB and oddly is now obsolete from VW. The equivalent Bosch number is 0 258 003 604 and the Denso number is DOX-0118 so it should be OK. I will have a think.
  5. Re: Lousy fuel economy mk3 cab 1.6 AFT
    #25
    Mar 2017
    Serbia
    Ok Crasher, thank you! Tomorrow I will try one other used MAF to check the difference.
  6. Re: Lousy fuel economy mk3 cab 1.6 AFT
    #26
    1837 Post(s)
    I will only trust genuine VW AMM's (MAF) bought from a VW dealer, not even Bosch.
  7. Re: Lousy fuel economy mk3 cab 1.6 AFT
    #27
    Mar 2017
    Serbia
    After few days of testing, problem is still there. I got the same genuine AMM for couple of days and it is the same. What else should I check? Thermostat? Intake temperature sensor? Crasher, any ideas?
    Just to remind I changed, spark plugs, spark plug wires, ignition coil, dizzy, rotor arm, lambda sensor, coolant temperature sender, air filter, fuel filter, AMM...No faults on VCDS/VAGCOM.
    P.S. I noticed that there is the same problem on some MK4 1.6 AKL engines wich is the same engine like AFT in MK3...
  8. Re: Lousy fuel economy mk3 cab 1.6 AFT
    #28
    1837 Post(s)
    The AKL has a slightly different engine management system and can be a pain. If the car is showing proper lambda correction under +/- 10% and not bringing up an error you are a bit stuck. The only next step is to accurately monitor the air/fuel ratio with a wide band lambda unit such as the one I am just putting in an R32 turbo so I can independently monitor the AFR.
    X-Series Wideband UEGO AFR Sensor Controller Gauge | AEM
  9. Re: Lousy fuel economy mk3 cab 1.6 AFT
    #29
    Mar 2017
    Serbia
    That is very good, but I cant find it in my country. Btw here is the video of VCDS measuring blocks on my car. I noticed today that when I step on the gas harder the drops of water go out of exhaust, is that some sign or?
    What do you think about the measurements, look good? Sorry for video quality...
    20170418 190703 - YouTube
  10. Re: Lousy fuel economy mk3 cab 1.6 AFT
    #30
    1837 Post(s)
    From what I can see the figures look correct but it was hard to focus on the video. There are alternative AFR gauges to the AEM unit, that is just one idea. Google "AFR gauge"
  1. A4 1.9 TDi (130) Sport Fuel Economy
    By ianward in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-05-2011, 07:22 PM
  2. DOA: 1.6 1996 golf mk3 Magneti Marelli (AEE) engine
    By carlthom in forum Golf MK3 - 1993 - 1999
    Last Post: 07-04-2008, 02:53 AM
  3. The way we talk about fuel and why it is so confusing.
    By Ben in forum Chat - Anything with wheels
    Last Post: 02-01-2008, 10:50 PM
  4. Remapping for fuel economy
    By Techno79 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-08-2007, 03:05 PM
  5. A4 Fuel problem
    By daz in forum Archive posts
    Last Post: 03-09-2005, 10:45 PM
