Thread: Octavia 1.9 Diesel DIY cambelt change
  1. Wink Octavia 1.9 Diesel DIY cambelt change
    Jan 2010
    London
    Hi there,
    My friend has a Octavia 1.9 Diesel and its due its cambelt change, I am a pretty good home mechanic and have done changes before in my drive, do I need special tools to to the job and how complicated is the process??
    Regards
    Daniel
  2. Re: Octavia 1.9 Diesel DIY cambelt change
    Jan 2009
    towcester northants
    there are special tools!
    if you feel compent enough then you could get by BUT be very carefull
    Hi Daniel, Is the Octavia an sdi? I have done the belt on my wifes polo diesel which is basically the same I would have thought, on 3 or 4 occassions. It is fairly straight forward. There is a plug on the top of the gearbox which reveals the zero mark on the flywheel ( you will need a torch) If you take off the rocker cover, the end of the cam away from the belt has a slot in it which you can stick a piece of flat metal plate in to keep the cam in position and the injector pump has a hole in its sprocket which lines up with a hole in the casting behind. I normally use a long reach socket in this from memory. It normally takes me about 3 to 4 hours on a Saturday with frequent coffee breaks! Hope this helps! Good luck!
  1. Question DIT Cambelt Change
    By Danny Angelface in forum Octavia
    Last Post: 21-01-2010, 06:51 PM
  2. New Cambelt - change water pump?
    By RichieG in forum Golf MK5 - 2004 - 2009
    Last Post: 12-04-2008, 12:31 PM
  3. Cambelt Change - Mk3 Golf Gti 16v
    By dravidham in forum Golf MK3 - 1993 - 1999
    Last Post: 18-10-2007, 09:40 PM
  4. Replies: 3
    Last Post: 20-09-2007, 08:59 PM
  5. 1999 polo tdi 1.9 cambelt change
    By stevezephyr in forum Polo - Derby - Lupo - Fox
    Last Post: 18-02-2007, 07:11 PM
