Thread: GOLF 03 plate - rear doors wont open HELP!
  1. GOLF 03 plate - rear doors wont open HELP!
    Jan 2010
    Birmingham England
    My two back doors will not open they are closed and cant open from inside or out!
    Does anyone know what part is required to fiox this and how much am i lookin to get them both done?
    Any help would be appreciated!
    Thanks x x x
  2. Re: GOLF 03 plate - rear doors wont open HELP!
    Norfolk
    You need a code read. It could be a can-bus wire problem or even two faulty doors. A code read will tell you if the ccm has lost communication with the doors.
  3. Re: GOLF 03 plate - rear doors wont open HELP!
    Jan 2010
    Birmingham England
    I did take it to a garage and they said it would cost me £400 because of the labour but didnt actually tell me what the problem was!
    Do you think that sounds about right ?
    x
  4. Re: GOLF 03 plate - rear doors wont open HELP!
    Dec 2006
    I have moved your post into the Golf Mk4 section.
    Rick
  5. Re: GOLF 03 plate - rear doors wont open HELP!
    Norfolk
    Look in the vag-com section on here. See if someone will code read it for you. It could be something as simple as damaged wires or it could be faulty door modules. Only a code read will give you a hint.
  6. Re: GOLF 03 plate - rear doors wont open HELP!
    Jan 2010
    Birmingham England
    Ok will do thanks Ive got someome looking atit this week hopefully so I will see if they can do the code read for me ... I'll let you know how i get on
    Thanks again
  1. Rear doors wont open from inside
    By dean-nez in forum Golf MK4 - 1999 - 2004
    Last Post: 25-04-2008, 10:43 PM
  2. Rear Door Locks
    By GSD in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-01-2008, 05:54 PM
  3. 24 MILLIONTH GOLF ROLLS OFF LINE - EXPANDED UK GOLF RANGE
  4. PRICING AND SPECIFICATION CONFIRMED FOR GOLF R32
    Last Post: 26-09-2005, 07:33 PM
