Thread: 80 coupe 2.6 gearbox prblem,,,please help
Results 1 to 10 of 13
  1. 80 coupe 2.6 gearbox prblem,,,please help
    Oct 2009
    Ashford Kent s,e England
    9 Post(s)
    Hi all
    THE CAR;1995 M REG Audi 80 2.6 coupe 5 speed manual front wheel drive.
    THE PROBLEM;
    This evening when leaving work I started the car and left to warm up for about 10 minutes,then drove away,;
    1st gear fine
    2nd gear fine
    3rd gear,wouldn't go in,so I missed it out and went to
    4th gear fine
    5th gear fine
    There is no nasty noise or crunching or grinding when attempting to select 3rd gear,it just won't go in.
    Coming down the box from
    5th to 4th fine
    4th to 3rd,,no
    3rd to 2nd fine if a little odd feeling
    2nd to 1st fine
    selection of reverse is also fine
    When driving along there is still no noise or nasties
    If I select from 4th to 3rd and really give it a shove, it will go into 3rd and still makes no nasty sound.
    It's as though there is a lump of timber or something in front of the gearstick blocking the way unless I shove it in hard.
    Question 1; is the gearstick direct into the box or does it have remote external linkage.
    Question 2; does this sound like a simple lack of gear box oil
    The car had alledgedly had a new clutch around 4 thousand miles ago and has always felt good and right
    The gearbox selection has been one of the nicest things about driving the car with such a silky smooth operation and has not once given cause for concern.
    As daft as it may sound I managed 3rd sat on the drive but it felt as though the gear was closer to 1st than usual....wierd.
    I know that it is nothing I'm doing wrong as I drive with 16 forward and 4 reverse in a splitter box with range change all day long
    Sorry to have gone on but a bit of brain power from you all would be extremely well recieved
    Many thanks
    Stuart
  2. Re: 80 coupe 2.6 gearbox prblem,,,please help
    Oct 2009
    9 Post(s)
    I'm going to try getting it in to the workshop at work tommorow to check the oil level
    If low what type of oil should it take,regular EP ?
    Stuart
  3. Re: 80 coupe 2.6 gearbox prblem,,,please help
    The oil isn't the problem here.there is something wrong with the 3rd gear syncromesh
  4. Re: 80 coupe 2.6 gearbox prblem,,,please help
    Oct 2009
    9 Post(s)
    I would have expected a worn or failing synchro to grind etc ,but I'll keep looking ,thankyou so far
    Stuart
  5. Re: 80 coupe 2.6 gearbox prblem,,,please help
    42 Post(s)
    976 Post(s)
    Does it go into 3rd at a standstill with the engine off?
    If you care about the future of the planet, read this and watch the video
    https://www.bosch.com/stories/synthetic-fuels
    "I disapprove of what you say, but I will defend to the death your right to say it"
    Evelyn Beatrice Hall (1868-1956)
  6. Re: 80 coupe 2.6 gearbox prblem,,,please help
    Oct 2009
    9 Post(s)
    Hi Steve, yes she will select 3rd when stationary and switched on or off but I have noticed on the way to work this morning that if I try 3rd but aim a bit toward 1st she will go in nicely.
    Just to update things I manged to clamber underneath this evening after work just to inspect things and discovered there is an oil leak(clean gold gear oil,..smelly)
    On further investigation I found that the oil fill plug was about 50% undone and only finger tight
    I am thinking now more so than before that she is probably low and causing the dry sticky selection
    What do you think and what were you aiming at?
    I only have to drive about 5 miles at quite low speeds to get to work, so I am hoping to top her up in the morning and see if there are any improvments on selection
    Your opinion!?
    Stuart
    PS should I be using standard EP80 OR EP90 TO TOP UP?
  7. Re: 80 coupe 2.6 gearbox prblem,,,please help
    42 Post(s)
    976 Post(s)
    Well if it will go in fine at a standstill engine off that suggests a syncro problem but it you can compensate by aiming the shift that suggest a linkage or selector problem which could be the UJ on the shaft, a problem with the base selector ball or a problem in the box. It needs to be up in the air with someone moving the lever, looking for lost movement underneath.
  8. Re: 80 coupe 2.6 gearbox prblem,,,please help
    Oct 2009
    9 Post(s)
    Steve , is the base selector ball at the bottom of the stick and maybe nylon?
    The UJ seems to have a bit of play but nothing excessive
    Can the base ball be replaced?
    Can the UJ be replaced ?
    Is there any linkage adjustment to be had?
    Any idea of parts cost and if straight forward to do?
    Which oil should I use?
    I can get oil tomorrow but which type?
    Thank you so much
    Stuart
  9. Re: 80 coupe 2.6 gearbox prblem,,,please help
    42 Post(s)
    976 Post(s)
  10. Re: 80 coupe 2.6 gearbox prblem,,,please help
    Oct 2009
    9 Post(s)
    Thanks for the above Steve, am I right to assume that the base ball is the golf ball below part 26.
    And does the UJ come complete with the shaft part 20
    Stuart
  1. Gearbox oil level
    By mowjoe in forum Golf MK4 - 1999 - 2004
    Last Post: 13-08-2009, 01:11 AM
  2. ** Manual Gearbox Problem 93 Polo CL Coupe **
    By VWPeoplePower in forum Polo - Derby - Lupo - Fox
    Last Post: 24-04-2008, 12:09 PM
  3. Replies: 0
    Last Post: 01-08-2007, 08:28 PM
  4. Audi Cross Coupé quattro - The compact performance SUV
    Last Post: 21-04-2007, 05:41 PM
  5. Audi 80 2.6 Coupe
    By acer80 in forum 80 - 90
    Last Post: 10-04-2007, 12:19 AM
