Thread: 2.0T engine codes and detailed specs
  1. 2.0T engine codes and detailed specs
    Jan 2010
    Dublin, Ireland
    I'm the new owner of a 2.0T B7 quattro. Is there somewhere to find the detailed specs of the various 2.0 TFSI engines? Mine has the BUL engine code (as per DTM model) and I want to see the difference bar a different map (e.g. updated turbo, pistons etc) for all the different codes.
  2. Re: 2.0T engine codes and detailed specs
    Southern County Softy
    20 Post(s)
    http://igorweb.org/equidec/
    Look in your handbook for the option codes, input them into the link for the options fitted to your car.......or phone Audi CS, give them the reg No, they will tell you what is fitted..
    A4 2.5 tdi QS (mapped)
  3. Re: 2.0T engine codes and detailed specs
    Jan 2010
    Dublin, Ireland
    Thanks very much. That is rather interesting and useful. The site doesn't however give any detail on the engine code (BUL), i.e. Ko3 turbocharger, compression ratio etc. Would you (or anyone) know where this sort of information can be found?
  4. Re: 2.0T engine codes and detailed specs
    20 Post(s)
    You might find the info your looking for on the TDI club site....
  1. Buying Oil, Some Basic Advice From Opie Oils
    By oilman in forum Chat - Anything with wheels
    Last Post: 13-10-2015, 11:16 AM
  2. Basic Oil advice from Opie Oils
    By oilman in forum Chat - Completely Off Topic
    Last Post: 09-09-2009, 03:11 PM
  3. A3 1.9TDi PD130 servicing intervals
    By michaelab in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 09-06-2007, 04:12 PM
  4. Vag-Com : clear fault codes
    By keland in forum VCDS - General Questions
    Last Post: 11-05-2007, 09:43 PM
  5. Option Codes
    By Samcat in forum Passat - Archive Topics
    Last Post: 23-11-2006, 11:25 AM
