Thread: Strange light issue
Results 1 to 10 of 12
  1. Strange light issue
    Sep 2007
    Essex boy in Suffolk
    Noticed tonight on my way home that when the wheels spin and the ESP kicks in the headlights dim,
    Had to try it a few times just to be sure (fun in the snow ) and it does it everytime.
    Not that bothered by it cos I wont see it that often when this white stuffs gone, just curious if anyone noticed it on theirs.
    Graham
    Still pretending to know stuff.
    Golf 6 .:R
    Corrado 20vT - BBS RCs, Leather, Bremo's, TFSI and DSG
  2. Re: Strange light issue
    Poole, Dorset
    I'll give it a go tomorrow and let you know, should be fun!
    Audi A4 3.0 QST B6
    Mercedes 190e 2.6 w201
    Mercedes 190e 1.8 w201
  3. Re: Strange light issue
    i wonder id the esp system uses alot of power to correct wheel spin, interesting to see if it happens to evryone, do you have HID or normal headlights?
  4. Re: Strange light issue
    Sep 2007
    I did wonder if the ESP used alot of power
    I only have normal non HID lights
    Graham
    Golf 6 .:R
  5. Re: Strange light issue
    Nov 2008
    Beds
    Theres no fun to be had in the snow with the ESP on!
    Audi A4 B6 Avant Sport 1.9TDI (SOLD)
    His: BMW 123d Coupe Auto
    Hers: Audi A4 B8 2.0TDI 143 Multitronic
  6. Re: Strange light issue
    Nov 2008
    N/A
    I saw it too, also happens when you slam the brakes on, or if you pull both front window buttons up (and hold them).
    Try this: Air con to AUTO, moderate temperature... activate the front window washers... report back when you've tried it!
  7. Re: Strange light issue
    Manchester, UK
    mine doesnt do that.. but my car slipped out and spun around a roundabout yesterday and even though i put my clutch in, the car stalled? so i went to a car park and tested it out again, got the back end to slide out and the esp goes beserk but then the car stalls.. im sure this isnt normal..
  8. Re: Strange light issue
    Dec 2006
    Quote Originally Posted by badboi4lyff View Post
    That sounds more like the idle speed is not ticking over correctly, therefore when there is a large power drain due to the ESP/ABS kicking in, its knocking the engine down to idle and then cutting out,.,
    Is the engine ok from stalls if you dip the clutch really fast ??
    In regards to the lights,,
    I have noticed a drain in the past before if you have everything turned on (FULL) and then drop down all windows..
    Its fine... I have a HID kit but not seen it with that.
  9. Re: Strange light issue
    Jul 2008
    I have also noticed this, lights dim when esp kicks in, windows switches both pulled up, I personally think its the standard a4 battery not having enough juice in it.
    2001 AUDI A4 1.8T SPORT
  10. Re: Strange light issue
    Quote Originally Posted by RickT View Post
    Same. although if i break hard with HIDs on an abs kicks in, they do flicker just 1ce - i assume due to the drop in power
  1. Question Fog lights install
    By deadly4u2nv in forum Golf MK5 - 2004 - 2009
    Last Post: 26-11-2014, 12:59 PM
  2. HID Aftermarket kits - Not Legal....
    By RickT in forum Chat - Anything with wheels
    Last Post: 13-05-2011, 12:44 PM
  3. Foglights Retrofit - VW Jetta / Golf
    By RickT in forum Volkswagen
    Last Post: 27-06-2009, 06:06 PM
  4. "How To" The FAQ & How To Thread
    By Ben in forum General
  5. Low beam bulb
    By inertia in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-03-2007, 11:50 PM
