Thread: Key cutting & remote coding help
Results 1 to 9 of 9
  1. Key cutting & remote coding help
    Aug 2009
    milton keynes
    Hi guys
    I am confused. I require a a second key and remote for by B7 05 TDI and, having optained a remote key fob with the same part number as the existing I went along to the dealer and ask them to cut me a new key and code the remote I brought. Dealer advised that both key and remote comes as one part even if say your key is broken you must purchase a new remote fob and key as there is a chip in the key? (pass). Can anyone of you fellow members point me to a place where I can purchase a new key or if I get one from fleabay, where can I go to have the new key cut and the remote coded? Anywhere between Milton Keynes and London I am happy to travel. Or is it just a dealer only?
    Thanks for your advice
  2. Re: Key cutting & remote coding help
    Dec 2007
    key from ebay then find a good locksmith to cut
    then find someone with vcds that can code the imobilser to the car i know shark can give him a pm
  3. Re: Key cutting & remote coding help
    Aug 2009
    milton keynes
    Quote Originally Posted by bez101 View Post
    Thank you for the info
    regards
  4. Re: Key cutting & remote coding help
    Jan 2010
    Southend, Essex
    Hi. I need a new key too. Not too bthered if is a remote, just something for emergencies if I lose my only key. No locksmith i can find will touch it - something to do with the chip. Is it a dealer job? If so how much will it cost? Or is the locksmith wrong - if he cuts a key is it going to work?
    Many thanks.
  5. Re: Key cutting & remote coding help
    Mansfield, UK
    No, the key needs coding to the car, you can't just cut a key unfortunately. It's not necessarily a dealer only job, I can do it and I guess some others may be able to also.
  6. Re: Key cutting & remote coding help
    Jan 2010
    Southend, Essex
    Quote Originally Posted by shark_90 View Post
    Ohright. When you say you can do it, are you a mechanic, or a locksmith - how come you can do it but others can't?
  7. Re: Key cutting & remote coding help
    Mansfield, UK
    I don't know if you can see my signature or not, but I'm a VAG specialist auto electrician.
  8. Re: Key cutting & remote coding help
    Jan 2010
    Southend, Essex
    Oh yes I can. Sorry, I didn't look before. I will go to a local specialist thenand see if they can do it. You are a bit far away! Thanks.
  9. Re: Key cutting & remote coding help
    Jan 2010
    Southend, Essex
    Does anyone know somebody in the Southend area that can do this?
  1. Audi a8 2003 Current gearshift program problem
    By eints77 in forum VCDS - Help Requests
    Last Post: 20-07-2010, 02:58 PM
  2. Key coding problem.
    By njonesn in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-01-2010, 08:52 PM
  3. Problems with Nav retrofit MMI A6 2008
    By craiglett in forum In Car Entertainment
    Last Post: 31-12-2009, 11:27 AM
  4. low engine power from cold
    By saabsalltheway! in forum VCDS - General Questions
    Last Post: 30-11-2009, 10:21 PM
  5. Please Help Central locking works fine but remote doesn't
    By john_richter in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-04-2009, 02:46 PM
