Thread: mk2 octavia rear window element !!!!
  1. mk2 octavia rear window element !!!!
    Jan 2010
    cheshire
    hi all hope someone can help me have a problem with the 25 amp fuse that protects the rear window element, the 25 amp is melting tried a lower rating ie 15 amp and that is getting very hot can not leave either in or i am going to get a fire.....hope someone can help me thanks...
  2. Re: mk2 octavia rear window element !!!!
    May 2008
    Take it to an auto-electrician. Dont be messing with different fuses if you dont know what your doing.
  3. Re: mk2 octavia rear window element !!!!
    Nr Wellingborough
    Sounds like you have a short in the wireing rather than a Heater fault, if you cant trace it your self then as above, if the standard fuse is 25a then fitting a 15 is daft, have you tried a new 25a - also check the fuse holder for corrosion/shorting to ground.
  1. Rear Window not working?
    By FoxA6 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 28-01-2017, 12:48 PM
  2. Question Golf Mk4 GT TDI Rear Wheel Bearing
    By tommi in forum Golf MK4 - 1999 - 2004
    Last Post: 25-05-2009, 08:21 PM
  3. Wishbone Front / Rear Axle Bush which brand
    By MathewRB in forum Golf MK4 - 1999 - 2004
    Last Post: 23-05-2009, 12:27 AM
  4. rear window
    By domg in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-04-2009, 12:25 AM
