Thread: Cleaning a blocked DPF
Results 11 to 20 of 21
  1. Re: Cleaning a blocked DPF
    May 2007
    knee deep in clunge
    14 Post(s)
    Quote Originally Posted by randall977 View Post
    Is there any rule to which cars Audi put the DPF on? Mine is a November 2006 TDI 170...I've just ordered a Diesel box btw...
    Do nit fit those crappy box's they block dpf for fun no matter what the sellers say they are shi t
  2. Re: Cleaning a blocked DPF
    Jul 2006
    Agree completely
    had one fitted to my 170 2.0 tdi Golf - it was fine for a day then played up something rotten, running lumpy, DPF light on/ off all the time, so took it off then had nothing but DPF issues.
    not recommended at all, complete waste of time and money, then nothing but grief.
    2005 Audi A4 S-line 2.0tdi Avant
  3. Re: Cleaning a blocked DPF
    Jul 2010
    ireland
    hi the dpf ligth has come on on my 07 audi a4 sline quattro. i drove it hard and went out but has come back on an will not go off after being driven hard again. what could solve this or what should i do? thanks
  4. Re: Cleaning a blocked DPF
    May 2011
    Luton
    Quote Originally Posted by a8 tech View Post
    If you follow the correct process and all the associated sensors are correct then emergency regen is required only if you have failed to carry out the correct driving profile when prompted by the regen light displayed on the dash.In your case the emergency regen would simply have done this for you but only via vcds or vas pc.At this time of year we find the tubing pipes freeze causing incorrect pressure readings but most common cause I have found is the g450 sensor.
    The emergency regen is pretty successful but you need................
    a HUGE and BIG thanks to ''patrickhorton'' and ''a8 tech''
    I had same problem as patrick(same engine audi a4 56plate 170 ). filter cleaning light came on and i just kept it ignoring as it was third time it came in the region of 6 months, after a week ignition coil light came and car went into limp mode. at that point i realised that i made a Big mistake and should have took it on motorway to clear it as always but was very busy and it didn't happened this time.
    SO searched every where for solution. was quoted from £400(cleaning or removing DPF) to £1400 installation of new DPF.
    Its midnight and i am writing to Say thanks to ''patric'' who started this thread and another thanks to ''a8 tech'' who's solution did work for me. Patric method was really good but had so much effort involved in it so i used Ross-tech method(advised by a8 tech) and it has worked very well.
    THANKS
    1 1 0
  5. Re: Cleaning a blocked DPF
    Jul 2008
    Stafford
    Glad your sorted CH_Mudasser. The forced regen is definitely the easiest fix so log as you aren't having to do it too often and the car is driving well for you.
    Sooner or later though all these DPFs will reach end of life. No amount of forced regeneration will remove the accumulated ash. It is a consumable part lasting up to 150k miles if you're lucky. At that point everyone will be faced with the choice of £1500 replacement or removal along with a non-audi remap to the ECU or do what I did. Mine has now done well over 10k on a modified DPF. I haven't reported it much as I don't want to push my luck. The mod cost about £20.
    It is going to be really interesting following this subject in a couple of years time when the 170 B7s come of age...
    Patrick
  6. Re: Cleaning a blocked DPF
    Feb 2010
    Manchester
    Sorry to drag up an old thread, i've been trawling forums for a bit of help as I have the same problem in an A3 (i know this is the A4 bit). @A8Tech - do you have any tips on how to resolve this on a 2008 A3 170? I have glow plug, emissions and DPF light on aswell as limp mode at the moment. It's covered 45k miles, only bought it a couple of weeks ago and tried running it but it's not made a blind bit of difference. It's also an S-tronic so have little control over the gears and revs etc
    I'm in Manchester if anyone can recommend someone who can fix it - tried VAG tecnik but the guy's away for 2 weeks
  7. Re: Cleaning a blocked DPF
    #17
    Jul 2008
    Stafford
    It's got to be worth going to the dealers for an emergency regen first to see if that fixes it for good. Surely it would be no more than an hour's labour and no parts are needed. If the fault comes back you will have to look at other ideas.
    Good luck
    Patrick
  8. Re: Cleaning a blocked DPF
    #18
    Oct 2010
    London, England
    Quote Originally Posted by jrsteeve View Post
    It's also an S-tronic so have little control over the gears and revs etc (
    Surely the S-Tronic has a tiptronic mode that allows you to select gears manually, does it not?
    A4 3.0TDi SE Quattro Tiptronic in Quartz Grey.
    On order: S4 Black Edition Saloon in Tornado Grey with Fine Nappa black/silver leather.
  9. Re: Cleaning a blocked DPF
    #19
    Nov 2013
    london
    Hello i am new to this website and was reading about the issue on a dpf ,
    i have had a same problem occur with my audi a3
    170 bhp Saturday morning my dpf light came on i was going to take it for
    a run on the motor way but said i do it when its clear on Monday evening
    the glow light started flashing i called the rac guy and he said there's
    nothing wrong apart from the dpf which live data read particle filter -9% any
    information would be very helpful
  10. Re: Cleaning a blocked DPF
    #20
    May 2018
    London
    I'm in exactly the same boat as you. I just wanna know, how long do you have to drive the car for and what particular speed and revs?
  1. Please Help Best Golf for £10k and confusion over different engines?
    By deshg in forum Golf MK5 - 2004 - 2009
    Last Post: 21-09-2010, 07:47 PM
  2. XP - Very Slow on Start up...
    By RickT in forum Home Tech Shed
    Last Post: 16-08-2010, 05:56 PM
  3. Diesel Particle Filter
    By prolfe in forum Chat - Anything with wheels
    Last Post: 08-10-2009, 07:08 PM
  4. Trim Confusion
    By ocelot0411 in forum Golf MK5 - 2004 - 2009
    Last Post: 15-08-2009, 11:16 AM
  5. Please can someone help
    By Daz9048 in forum Golf MK5 - 2004 - 2009
    Last Post: 05-07-2009, 08:34 AM
