Thread: Vag com not finding ecu
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. Re: Vag com not finding ecu
    Ambler, PA, USA
    Only other thought I have is a bad connection at the DLC. Is it possible something has messed with the wiring harness and damaged the lines such that you are not able to make a good connection? Take a look at the aftermarket radio page because it shows the wiring to the DLC and I'd start looking for a problem there.
    Outside of that idea, I have no better clue. It still could be one of the burried modules but I would find that hard to beleive since nothing is communicating. You did check for power at the DLC - right? There is a fuse and the DLC has got to have power for the interface to fully work.
  2. Re: Vag com not finding ecu
    Dec 2008
    East Preston, West Sussex
    not HVAC...
    12v at the connector
    John
    2005 A4 B6 Avant 1.9 TDI 130 Sport (6)
  3. Re: Vag com not finding ecu
    Ambler, PA, USA
    Have you tried what we call a cold boot? disconnect the battery - both terminals - short the battery leads together for a couple of seconds - wait a few minutes - then reconnect the battery. This forces all modules into a total restart and sometimes will get a module that is hung to restart and begin communicating. Normally we tell people to do this as a last resort. Seems you might be there.
  4. Re: Vag com not finding ecu
    Dec 2008
    Bruce, I will give this a go in the next few days and let you know the outcome. Other cars now have priority.
    John
    John
  5. Re: Vag com not finding ecu
    Dec 2012
    helmsdale, scotland
    I have the same problem with one of my Audi 80 tdi's VCDS will talk to all my other cars (4) except one. tried all the above but strange, vcds can find the controller but after starting the car VCDS can no longer find the controller
  1. Can i swap my auto gearbox and ecu with another model B5?
    By eddy7679 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-09-2009, 03:51 PM
  2. "How To" The FAQ & How To Thread
    By Ben in forum General
  3. Replacement ECU
    By brendanm in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-11-2007, 02:12 PM
  4. Are And Vag Com / Vag Tacho The Same
    By davecoz in forum VCDS - General Questions
    Last Post: 21-11-2007, 09:13 AM
  5. Replacing Alarm Central locking ECU
    By diode in forum Audi A4 - Archive Topics
    Last Post: 11-01-2007, 04:33 PM
