Thread: Touran Fuse Box in engine compartment
Results 1 to 10 of 18
  1. Touran Fuse Box in engine compartment
    Dec 2009
    Salisbury, Wiltshire
    Could anybody point me in the direction of a diagram for the fuse box located in the engine compartment of a 2004 Touran 2.0 TDi Sport?
    Many thanks.
  2. Re: Touran Fuse Box in engine compartment
    1840 Post(s)
    To find the unit itself or a schematic of the fuse layout? Are you looking for the fan fuse?
  3. Re: Touran Fuse Box in engine compartment
    Dec 2009
    Sorry, I should have made myself clearer. I require a schematic of the fuse layout - I want to check the fuse for my radio/CD player.
  4. Re: Touran Fuse Box in engine compartment
    1840 Post(s)
    It is called SB19 as that fuse box area is called SB but the fuse is numbered F19 on the box itself.
  5. Re: Touran Fuse Box in engine compartment
    Nov 2006
    Kenilworth, Warwickshire
    Hi Crasher
    Sorry to hijack the thread but I'm having problems diagnosing the inoperative electric windows on my 2004 Caddy and I can't find any fuses or relays which supply the windows. Does the fuse box under the bonnet contain anything relevant and if so which numbers?
    Acually my problem may not relate to fuses because I do get a click from the window motor or control module when I operate the switch, but the motor doesn't operate. But before I go down the very costly route of new motors/controllers I want to be completely certain that the problem doesn't lie somewhere else.
  6. Re: Touran Fuse Box in engine compartment
    1840 Post(s)
    PM me the cars reg, Caddy electrics are a bit odd at times.
  7. Re: Touran Fuse Box in engine compartment
    Nov 2006
    Many thanks Crasher. I've sent you a PM.
    Mike
  8. Re: Touran Fuse Box in engine compartment
    Feb 2013
    derby
    Any ideas what fuse it is for the tailgate on an 04 touran?
  9. Re: Touran Fuse Box in engine compartment
    1840 Post(s)
    There are multiple different layouts according to spec and year so it depends on the system but UK cars tend to have the convenience system where the power feed is to pin 4 of the 4 pin plug on the green/white wire which is directly from the central convenience system J393 with no separate fuse. Check fuse 29 and 53 on the under dash fuse panel but if it is the type with power from fuse 29, the rear wiper motor will not work either
  10. Re: Touran Fuse Box in engine compartment
    Mar 2013
    nottingham uk
    Hi, I have a 2010 pre new shape Touran Diesel and having a bit of a nightmare getting to know my fuse box...(s) I asked my dealer and they say they cannot give information about fuse lay outs?????? why????? I can't find anything on net apart from pre 2007 models so I bought elsa discs from ebay and that doesnt give any information on fuse box layout. So can anyone let me know how to obtain a fuse box layout diagram.. (mainly the under dash one) Please....
  1. oil warning signal
    By ger83 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-11-2009, 07:20 PM
  2. VW Golf 1.6 FSI Engine noise
    By David Farmer in forum Golf MK5 - 2004 - 2009
    Last Post: 13-05-2009, 11:10 AM
  3. "How To" The FAQ & How To Thread
    By Ben in forum General
  4. A4 95/96 Engine Management Fuse blowing
    By PClements in forum Archive posts
    Last Post: 01-11-2007, 09:46 PM
  5. Answers From The Oil Expert Part 2
    By oilman in forum Archive posts
    Last Post: 22-10-2007, 08:30 AM
