Thread: Installing blue interior lights, advice req.
  1. Installing blue interior lights, advice req.
    May 2007
    Hi all just new to the forum so hello, I have a 54 plate Passat and am in the middle of converting its interior bulbs to blue, looks good and matches the dash! BUT i have a big problem, the dome lights in the rear are integrated into the cars interior sensor system, i managed to get the bulb out but have never seen the likes of this bulb, the front ones were easy being festoon and normal led changes but as i say the rear ones are a problem, they are 12v 3.8w and attached to a "screw" system for removal.
    Has anyone successfully changed these bulbs or have any idea where i can get them in blue??
    Thanks in advance.
    Coventry
    sorry cant help with the bulbs, how about changing the colour of the lens, paint it blue, or use blue nail varnish, something that wont melt with the heat of the bulb or fade too quickly.
    May 2007
    Thanks for the reply, yes i had thought of painting the actual bulb maybe not the lens just incase we ever want to change colours , never know modding is adictive eh ?? so i was looking at different heat resistant paints no luck as yet, maybe radiator paint would o but not sure about how much " luminance " i would get when the bulb was painted!
    Jun 2006
    UK, Mids
    I got a W8 front light and replaced the 4 W5W bulbs for some LED-based ones. The rear ones, I can't remember exactly, but I got the same W5W LED-based bulbs, and bent the wires straight on the wedge base and soldered them into the rear lamps, or onto the base, can't remember, and bent them at 90 degrees so they shone out of the lens.
    an expensive example....
    http://cgi.ebay.co.uk/Side-Parking-L...QQcmdZViewItem
    how did you get to the bulb in the first place i cant replace my broken bulb..
  6. Re: Installing blue interior lights, advice req.
    Apr 2007
    norfolk
    this may be a bit late now but you can che ck out www.ultraleds.co.uk on this web site there is a tab for automotive led which has a wide variety of colours and types of bulb i have just done some of the bulbs on my a3 and they look great
    hope this helps if its not too late
  1. interior lights
    By gibo.drum in forum Chat - Anything with wheels
    Last Post: 18-02-2008, 09:43 PM
  2. Interior Lights.
    By Jez. in forum Passat - Archive Topics
    Last Post: 17-04-2007, 04:56 PM
  3. Pulsing interior lights? What's that all about then?
    By Niall76 in forum Archive posts
    Last Post: 23-02-2007, 10:09 PM
  4. Passat Interior Lights
    By JASTONV in forum Passat - Archive Topics
    Last Post: 17-12-2006, 09:31 PM
  5. Dodgy Interior Lights.
    By Jez. in forum Chat - Completely Off Topic
    Last Post: 29-03-2006, 08:41 AM
