Thread: Golf MkIII seat belt access
  1. Golf MkIII seat belt access
    Feb 2006
    Waterloo, Belgium - where Napoleon fought and lost his last battle in 1815.
    I have a 1994 Golf MkIII on which the driver's seat belt rewind has become sluggish. I don't know if this means a squirt of WD40 is needed or if a new belt should be fitted.
    In either case, can anyone please tell me how to access the belt mechanism?
    I have tried gently levering the central column trim but it seems very firmly fixed. Naturally, I don't want to cause any damage by being too brutal.
    Any advice would be greatly appreciated.
    Feb 2006
    Quote Originally Posted by brianf
    Still hoping for an answer to this. Can anyone tell me how to get at the seat belt mechanism without doing damage?
    Feb 2006
    Nottingham
    ive struggled with removing the same bit on my mk3!
    my rear door speakers dont work and the wires chase back through there!
    needless to say they still dont work as i never got it off!
    try a hanyes manual???
  4. sussed it
    Feb 2006
    Nottingham
    right,above the seat belt adjuster on the piller at the top in the middle there is one clip which is a bar stud to get off,I got in from the side and just pulled pretty hard! its doesnt come free as the belt still run's though it!
    once off there is one screw inside the lower part,pull belt to one side you'll see it,undo it and it pulls towards you,maybe a thin plastic sheet to guard seat belt this just pulls off easyly,hey pressto your in!
    it took a bit of wiggling to re fit but went back togeather with a fair whack!
    hope it helps mate!
    Ali
    Feb 2006
    Quote Originally Posted by ali-mk3 golf
    hope it helps mate!
    Ali
    Many thanks!
    That sounds like just the info I needed. I'll give it a go and report back.
  1. Coding Q7 instrument cluster to stop seat belt warning light
    By tune-tec in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 22-06-2008, 09:59 AM
  2. Seat Belt Extender
    By beastman in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-11-2007, 04:56 AM
  3. Rear Seat-Belt issue.
    By Westford in forum Archive posts
    Last Post: 04-04-2007, 02:27 PM
  4. Golf VR6 MkIII Electrics help pls!
    By mentalmike in forum Golf MK3 - 1993 - 1999
    Last Post: 15-06-2006, 11:38 PM
