Thread: Replace the heater matrix the easy way
Page 1 of 8 123 ... LastLast
Results 1 to 10 of 75
  1. Thumbs up Replace the heater matrix the easy way
    Dec 2007
    I had real problems and spent a lot of time looking into why I was getting no heat at all. After lots of investigation and trying different things, I bit the bullet and looked at replacing the matrix. The Haynes manual procedure looked a knightmare, I removed it in 20 mins without disturbing any major component or removing the aircon evaporator.
    The hardest part was refitting it and cleaning it out using the original seals and clips but it has been fine for three weeks now and the heat is brilliant.
    Hope it helps someone...
    http://www.splitsec.co.uk/Heatermatrixremoval.doc
    4 0 0
  2. Re: Replace the heater matrix the easy way
    Dec 2007
    well that wordpad doc gave me some daft coded ****
  3. Re: Replace the heater matrix the easy way
    May 2007
    knee deep in clunge
    14 Post(s)
    There is only one way to do it and use a carpet vac to remove the coolant or oil extracter
  4. Re: Replace the heater matrix the easy way
    Dec 2007
    what i ment b4 is the link u posted does not work for me it just gives me a daft code not anything else so can you copy and paste in to the thred also did you do the wordpad doc or find it on another site
  5. Re: Replace the heater matrix the easy way
    Dec 2007
    PM me your email address, i'll email it to you. Did it in Word 2003, can't upload 522kb, too big?!
  6. Re: Replace the heater matrix the easy way
    Dec 2007
  7. Re: Replace the heater matrix the easy way
    Dec 2007
    Sent, it's all my own work!!
  8. Re: Replace the heater matrix the easy way
    Feb 2010
    uk
    This is really good news, what i can't work out is why the vw ******** want £500 + to take all the dash out when it just pops out in to the drivers side foot well, are they just blatantly ripping people off or just not worked out the quick way?
    I was about to buy a tdi sport estate but the windows steamed up and i could smell coolant in the car and when i started looking about for heater matrix replacement i blew the car out, i might just have to take a punt on it now, I'm fairly competent mechanics wise (did the job for 15 years before my current role) so this should be a straight forward job. Similar to my 92 pontiac firebird by the looks of it.
  9. Re: Replace the heater matrix the easy way
    Sep 2008
    chester
    17 Post(s)
    Can you get it out with a manual without taking the clutch pedal out?
  10. Re: Replace the heater matrix the easy way
    Dec 2007
    I guess so, you'll have to take the shrouding off and see if it will come out - only a 10 min job.
    I'm amazed that VWAudi charge so much, I'll do it for half the price!!
  1. Replacing the heater matrix... the easy way!
    By Props Forward in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-01-2016, 02:52 PM
  2. Heater core replacement 93 passat VR6
    By farmhemi in forum Passat - Archive Topics
    Last Post: 05-01-2008, 04:25 AM
  3. Heater Matrix leaked, Radweld recommended or not??
    By TDI in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 11-03-2007, 03:15 PM
  4. Heater matrix reinstall difficulties
    By narge in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 18-11-2006, 11:13 PM
