Thread: Concert stereo not reading SD card or USB device
  1. Concert stereo not reading SD card or USB device
    Sep 2009
    England
    I have a 2009 A3 in which I have recently replaced the Chorus head unit with the Concert II+ head unit to enable me to play the MP3 CDs which I burnt for my previous car. Playing MP3 CDs work exactly as expected.
    When I purchased the vehicle I also had the combined usb/sd interface installed. However, I have been unable to get the stereo to play MP3s on either format.
    As other forums have highlighted that the interface may not support SDHC I have purchased a 4gb SD card but even with a folder containing a single album the stereo does not play the music.
    I have also tried adding an m3u playlist but that had no effect.
    When I insert the SD card into the interface the head unit shows CD5 as having a CD inserted but then does not play. If I select one of the other CDs it states there is no CD inserted. I get the same behaviour with the usb device. At no point do a get the "READING" message on the head unit which I get when inserting a CD.
    Could someone please put me out of my misery as I am sure I am probably doing something stupid!
  2. Re: Concert stereo not reading SD card or USB device
    Sep 2009
    England
    As a test I copied 5 random folders of MP3s from one of the CDs I had played successfully onto the SD card.
    Now the head unit shows CDs inserted in CD1 and CD2
    I assumed this was because one of the folders in the root directory contained folders called CD1 and CD2 as the music played corresponded to these folders.
    I therefore created 6 folders called CD# in the root directory of the SD card and into each put subfolders containing MP3 files and m3u playlists. This resulted in the same two sub-folders being detected as CD1 and CD2. Renaming the sub-folders resulted in no CDs being available again!
    So it does look like it is just the file layout that is causing me issues!
    Could someone please confirm:
    1) whether the concert will read m3u playlists?
    2) whether the mp3 files have to be in folders called CD1 etc?
    3) is anyone aware of a maximum bit-rate the the headunit will play?
    4) could someone describe a working file layout they have on an SD card?
    Any help would be greatly appreciated as I am getting sick of the rattle of CDs in the car!!
  1. Intermitent Power off - Concert Stereo
    By MikeLMR in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-09-2009, 11:51 AM
  2. CREDIT CARD SCAM... Pls read..
    Last Post: 30-11-2007, 03:08 PM
  3. Audi Concert stereo model # question with PIC
    By ianmatho in forum Archive posts
    Last Post: 27-10-2007, 01:56 AM
  4. vag com codes
    By marty67 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-02-2007, 09:12 PM
  5. Replies: 0
    Last Post: 29-06-2006, 08:27 PM
